Relay affects thermistor — Parallax Forums
cparkercparker Posts: 14
edited 2006-08-11 16:10 in BASIC Stamp
I have a question about making my simple thermistor circuit more percise.
Long story short: I am using a BS2, and a cheap radio-shack thermistor to build a simple cooling thermostat (fridge controller). I am using RCTIME to measure the capacitor discharge time through the thermistor as described in the BS2 manual. I'm using an LM317 3-terminal voltage regulator to provide 5 vdc to the stamp, and to the thermistor, and to a relay which controls the fridge compressor. Vin is provided by a 12v(ish) AC wall-wort adapter.
I've noticed that when voltage is flowing through the relay in order to close the relay ciruit, this has a somewhat significant affect on the RCTIME measurement of the thermistor. The affect is 3-4 degrees F.
Any ideas on how I can reduce the affect of the relay on the thermistor? Would it make sense to use two LM317s, one for the more-sensitive thermistor circuit, and another for everything else?
I'll draw a quick schematic if needed.
Thanks!
CP
    edited 2006-08-11 05:36
    Having a separate and/or isolated supply to your thermistor in a situation like this is not only a good design practice, but probably required for an application such as this.
    Go ahead and post a schematic, just in case something might be missed in the text description.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-08-11 15:18
    Along the lines of what Beau is getting at, what voltage is the Relay circuit and the thermistor circuit running from?· In a situation where the Relay was 12V but the BASIC Stamp and thermistor circuit was 5V the relay would be less likely to affect/impact the thermistor circuit.· Another option is to increase the resolution/sensitivity/stability of the readings by using an ADC0831 rather than RCTIME.· I hope this helps.· Take care.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • metron9metron9 Posts: 1,100
    You could use a Zener to regulate the voltage through the RC timer. Use a Zener to limit the charge to say 4V maximum. As long as the voltage with the relay on is above the zener voltage you should have the same time constant.
    Think outside the BOX!
