First post - Back into stamping but loop will not loop
Hey all, I recently got back into this basic stamp stuff
I have the BS2sx and BOE along with version 1.33 editor. I also recently downloaded what is a microcontroller and found my resistors and other goodies.
Tonight I plugged my BOE and stamp into the PC (Win XP) connected the 9 volt, wired up the circuit according to the PDF file (resistor, LED) fired up the editor and entered:
DO
HIGH 14
PAUSE 250
LOW 14
PAUSE 250
LOOP
I pressed run. Seen the LED light up and go out. Thats it. It did not loop. I pressed the reset button several times, changed time values and got the same. The program will not loop. I unplugged the BOE from my PC, removed the battery plugged the battery back in and same thing. One once off one. And thats it.
I even updated to version 2.2.6 of the editor and got the same response
Whats going on?
I have the BS2sx and BOE along with version 1.33 editor. I also recently downloaded what is a microcontroller and found my resistors and other goodies.Tonight I plugged my BOE and stamp into the PC (Win XP) connected the 9 volt, wired up the circuit according to the PDF file (resistor, LED) fired up the editor and entered:
DO
HIGH 14
PAUSE 250
LOW 14
PAUSE 250
LOOP
Whats going on?
Thanks!
Now what to build
Post Edited (slitherjef) : 8/9/2006 2:47:38 AM GMT
