First post - Back into stamping but loop will not loop
Hey all, I recently got back into this basic stamp stuff
I have the BS2sx and BOE along with version 1.33 editor. I also recently downloaded what is a microcontroller and found my resistors and other goodies.
Tonight I plugged my BOE and stamp into the PC (Win XP) connected the 9 volt, wired up the circuit according to the PDF file (resistor, LED) fired up the editor and entered:
DO
HIGH 14
PAUSE 250
LOW 14
PAUSE 250
LOOP
I pressed run. Seen the LED light up and go out. Thats it. It did not loop. I pressed the reset button several times, changed time values and got the same. The program will not loop. I unplugged the BOE from my PC, removed the battery plugged the battery back in and same thing. One once off one. And thats it.
I even updated to version 2.2.6 of the editor and got the same response
Whats going on?
DO
HIGH 14
PAUSE 250
LOW 14
PAUSE 250
LOOP
Whats going on?
Thanks!
Now what to build
Post Edited (slitherjef) : 8/9/2006 2:47:38 AM GMT
