trying to understand SSR's
hi all,
anyone know if you can take a SSR's rating for ex .. 45 A at 240vac and just multiply and use that power rating to adjust and find out if it will carry 90 amps at 12 Vdc· ??
in other words can you use its watt rating as a gauge ?
got to run a dc motor at 12 volts, i think the circut breaker for it is 50 Amps, might be higher
and i want to be able to run it forwards and back and brake... sounds like a H bridge i think
dan
dan
I can't speak for SSR's per se, but generally relay contacts are rated in ampacity, NOT in wattage as you suggest. Besides, I'd NEVER mix AC and DC ratings, regardless!
Bruce Bates
<!--StartFragment -->
Generally, designing high current switches (like maybe 50A). You want your devices to spend as little time as possible in their "linear" zone so that they switch very rapidly and thus don't produce much heat. For an H-bridge, you want to design it very carefully so that the two legs between + and - can never switch on at the same time. For the kind of current you're talking about, if you don't have some experience, I'd suggest sticking with a commercially produced device or a carefully designed, published circuit.
dan
I was doing some shopping and saw this item:
60V, 3A· solid-state relay --· http://www.alltronics.com/cgi-bin/item/96B002/search/60VDC%2D%40%2D3A%2DSolid%2DState%2DRelay
but thanks to the forum sending me off looking in a different direction than i had been surfing... i noticed a schematic that uses a DPDT mechanical relay to control direction of rotation, and a single power mosfet to control current flow...
you just turn off the mosfet b4 switching the relay to extend the life of the relays... so whereas DC SSR's are expensive, and i would need 4, by using automotive relays with high current capabiltys ( cheap on ebay ) to switch direction, and a single mosfet, to interupt the current, its much less for the pocketbook
