In a DAT section, constants are allocated in sequential order. If you change alignment on successive lines (byte to word or word to long), there may be unused space to do the boundary alignment, but, otherwise, it's strictly as you write it. For example:
myData word 1, 2, 3, 4, 5, 6, 7, 8
word 9, 10, 11, 12, 13, 14, 15, 16
This will create a word array with 16 elements that you can access with "myData[noparse][[/noparse]index]" or "word[noparse][[/noparse]@myData][noparse][[/noparse]index]".
myData word 1, 2, 3, 4, 5, 6, 7, 8 word 9, 10, 11, 12, 13, 14, 15, 16This will create a word array with 16 elements that you can access with "myData[noparse][[/noparse]index]" or "word[noparse][[/noparse]@myData][noparse][[/noparse]index]".
Caught in the PropWash
