Help with morse code program
I have two pushbuttons that I have made sure are working right in other programs. What is wrong with my morsecode program below? Possible it takes too much time to load, and it requires a lot of power. My homework's little green LED goes off when i hit the button that translates the letter attached to IN1. It does require a lot of memory... Is there a way to be a little more creative with the programming so it doesn't include all those ELSEIF statements? I'm also going to try a new 9-volt for it.
thanks,
AC
thanks,
AC
' {$STAMP BS2} ' {$PBASIC 2.5} counter VAR Word morse VAR Word a VAR Word 'a=amount dashdecoder VAR Word dotdecoder VAR Word top: DO IF IN0 = 0 THEN FOR counter = 1 TO 1 a = a + 1 IF a > 120 THEN morse = 2 ELSE '2- dash 1- dot morse = 1 ENDIF PAUSE 10 NEXT ENDIF IF morse = 1 THEN dotdecoder = dotdecoder + 1 ELSEIF morse = 2 THEN dashdecoder = dashdecoder + 1 ENDIF LOOP UNTIL IN1 <> 0 IF dotdecoder = 1 AND dashdecoder = 1 THEN DEBUG "a", CR GOSUB top ELSEIF dotdecoder = 1 THEN DEBUG "b" GOSUB top ELSEIF dashdecoder = 1 THEN DEBUG "c" GOSUB top ELSEIF dotdecoder = 2 AND dashdecoder = 2 THEN DEBUG "d" GOSUB top ELSEIF dotdecoder = 2 AND dashdecoder = 1 THEN DEBUG "e" GOSUB top ELSEIF dotdecoder =1 AND dashdecoder = 2 THEN DEBUG "f" GOSUB top ELSEIF dashdecoder = 3 AND dotdecoder = 1 THEN DEBUG "g" GOSUB top ELSEIF dashdecoder = 3 AND dotdecoder = 2 THEN DEBUG "h" GOSUB top ELSEIF dashdecoder = 3 AND dotdecoder = 3 THEN DEBUG "i" GOSUB top ELSEIF dotdecoder = 3 AND dashdecoder = 1 THEN DEBUG "j" GOSUB top ELSEIF dotdecoder = 3 AND dashdecoder = 2 THEN DEBUG "l" GOSUB top ELSEIF dashdecoder = 4 AND dotdecoder =1 THEN DEBUG "m" GOSUB top ELSEIF dashdecoder = 4 AND dotdecoder = 2 THEN DEBUG "n" GOSUB top ELSEIF dashdecoder = 4 AND dotdecoder = 4 THEN DEBUG "o" GOSUB top ELSEIF dotdecoder = 4 AND dashdecoder = 1 THEN DEBUG "p" GOSUB top ELSEIF dotdecoder = 4 AND dashdecoder = 2 THEN DEBUG "q" GOSUB top ELSEIF dotdecoder = 4 AND dashdecoder = 3 THEN DEBUG "r" GOSUB top IF dotdecoder = 4 AND dashdecoder = 4 THEN DEBUG "s" GOSUB top ELSEIF dotdecoder = 5 AND dashdecoder = 1 THEN DEBUG "t" GOSUB top ELSEIF dotdecoder = 5 AND dashdecoder = 2 THEN DEBUG "u" GOSUB top ELSEIF dotdecoder = 5 AND dashdecoder = 3 THEN DEBUG "v" GOSUB top ELSEIF dotdecoder = 5 AND dashdecoder = 4 THEN DEBUG "w" GOSUB top ELSEIF dotdecoder = 5 AND dashdecoder = 5 THEN DEBUG "x" GOSUB top ELSEIF dashdecoder = 5 AND dotdecoder = 1 THEN DEBUG "y" GOSUB top ELSEIF dashdecoder = 5 AND dotdecoder = 2 THEN DEBUG "z" GOSUB top ELSEIF dotdecoder = 3 AND dashdecoder = 5 THEN DEBUG " " GOSUB top ELSE DEBUG "Not in database!" GOSUB top ENDIF ENDIF
·Somebody said...
-Never Underestimate the power of human stupidity.
How about a lookup table?
your data goes from 1 to 5 on the dashdecoder and 1 to 5 on the dot decoder
so
Multiply dotdecoder by 5 and add dashdecoder
dotdecoder=5 * 5 = 25 + dotdecoder =1 table entry for array data 26 = 'z"
so
lookup=(dotdecoder*5) + dashdecoder
character=arraydata(lookup)
debug character
and get rid of all the if's and elseifs
Think outside the BOX!
