New Propeller Tool (v0.98)
Jeff Martin
Hi,
An updated version of the Propeller Tool software (v0.98) is available at our web site:
http://www.parallax.com/propeller/downloads.asp
There are a number of enhancements and fixes, including a fix to the bug causing STRING to fail inside of a CASE-OTHER block.
For a list of all changes, please read the Readme.txt file that is installed by the Propeller Tool software's installer.
This release brings the software closer to the version supported by the v1.0 manual.
We are working on enhancing the software further and fixing known issues, but if you find an issue that you don't think is known, please tell us about it.
Thank you.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Thank you.
--Jeff Martin
· Parallax, Inc.
Sid
Chip Gracey
Not complaining, just mentioning a point where some options for the user would make the experience better.. Thanks for the great work!
It's likely that the IDE gets the drive info from the user's registry settings, if the IDE account only has limited access, that's all the IDE should check for.
Of course, it might not work that way, but if you're having problems, it's worth checking out.
I am excited about it, but....
Don't rush. I can wait until FALL as the people that I am going to give copies are university professors.
It will be hard to find them right now.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 7/15/2006 11:18:38 AM GMT
I'm in no real rush, just would like to get the word in while it's all still being worked out.. Certainly isn't a show stopper.
THe issue is, when I insert my SD card or thumb drive into the PC, it never detects it!
It's bad programming to scan the entire storage system when a program is starting.
ON my network here at home, it takes the propeller over 3 minutes to boot,
My laptop is much better, I just turn off the wireless, boot the tool, then turn back on the wireless.
But my PC is a file / music / web and ftp server, and is connected to other, slower PC's.
Please Propeller Programmer Grueus, remove the drive scan on boot!
Make it so it only scans the directory it's launched from (or last accessed folder), and simply add a 'refresh' to the drive selector!
Just tossing my two bits worth into the bit bucket
KK
The software naturally will install into it's own folder unless you select "Custom" install when prompted; you can install over the existing folder if you wish.· Or, if you accept the defaults, it·will keep the older version on your system at the same time since they will not conflict with each other.
Sorry for the trouble with the drive scanning.· It is actually not scanning for all folders of a drive, just the drives themselves.· We're aware of the delay problem·and have a long-term solution that will work well for all situations, but it will take a little more time to implement it.·
For now, I'm working on a temporary solution that should take most of the "pain" out of it in the mean time.· I will post another one as soon as I make that change and will tell you·about it·at that time.
Thank you.
--Jeff Martin
· Parallax, Inc.
term.dec(TRUNC(holedepth))····
with V0.98 and it didn't work.· Had to put the CONSTANT back in.
Sid
Sid
Are you sure you were using v0.98?· I just tried it and it worked file.· Compiled fine and downloaded and ran with no problems.
--Jeff Martin
· Parallax, Inc.
When I made the installer yesterday, I accidentally left an artifact in from the previous installer, causing the desktop icon (Propeller Tool v0.95.1), if you have it on your screen already, to be rerouted to the new v0.98 software... but it is still labled v0.95.1.
Just so you know, it did not replace the v0.95.1 software, that is still on your computer unless you uninstalled it yourself... it only rerouted the icon for v0.95.1 to point to the v0.98 software.
I apologize for any confusion that may have caused.
--Jeff Martin
· Parallax, Inc.
Thanks for looking at the drive scanning issue for us. I do look foward to your short and long term answers.
KK
Now there is a v0.98.1 version of the Propeller Tool posted to the website:
This version has a feature that should help with the startup-delay issue.· There is a better fix coming in a later version, but I wanted to get this one posted in the mean time to try to help the situation.
The Propeller Tool's Integrated Explorer has always had a button to the left of the Recent List (the drop down control just above the Folder List).· This button is the "Show Recently Only" button, or "Recent" button for short.· It's a toggle button that, when pressed in, will cause the Folders List to only show drives and paths that are within the set of folders recently accessed by the Propeller Tool (folders that a file was loaded from).
The difference in this version (v0.98.1) is that the state of the the Recent button is now remembered between sessions; you can press it and if you close the Propeller Tool, the next time you restart it, it will only show you the recent folders in the Folder List.· This should speed up the startup time.· If you need to see all other folders, you can press the Recent button again to update the Folder List display with all drives and folders.
In addition, I was able to rearrange some code to allow the tool to show itself before the Integrated Explorer is finished loading, so that if you had launched it via double-clicking on a *.spin file from·Windows Explorer (for example), you could start reading the file even before the Tool is ready for your input.
As soon as possible, I will improve the responsiveness of the Propeller Tool even more·to try to erradicate this startup-delay and a number of other issues.
Thank you.
--Jeff Martin
· Parallax, Inc.
You're welcome. Thank you for being so patient.
--Jeff Martin
· Parallax, Inc.
As I have said to anyone who will listen to me about all of you guys at parallax...
"When you buy a part from them, you buy into a family! A great family at that."
Just think, heck, this is almost a tv ad...
[noparse]:)[/noparse]
Thanks again Jeff (and everyone else who's namless at this point who is also working on the project)!
KK
We appreciate all comments, but especially those!
--Jeff Martin
· Parallax, Inc.
I second KK's glowing advert! These things often "go without saying", and we sometimes forget how much a well-deserved pat on the back can mean. But always rest assured that beneath every ounce of critique lies a ton of appreciation.
So, okay, back to business now.
Phil
Took me a minute to grasp some of this propeller ideology, but once it clicks...
I'm just gonna toss this in for good measure
I could go all day, but seriously I'm very happy now and seriously glad to see a company do this sort of thing! 50 points!
My suggestions about the ctrl-shift-arrow/end.. woops, that was about another IDE for something else.. Not the propeller.. Ha. But the comment with ' comment stands
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
Hi again,
This version has a feature that should help with the startup-delay issue. There is a better fix coming in a later version, but I wanted to get this one posted in the mean time to try to help the situation.
The Propeller Tool's Integrated Explorer has always had a button to the left of the Recent List (the drop down control just above the Folder List). This button is the "Show Recently Only" button, or "Recent" button for short. It's a toggle button that, when pressed in, will cause the Folders List to only show drives and paths that are within the set of folders recently accessed by the Propeller Tool (folders that a file was loaded from).
The difference in this version (v0.98.1) is that the state of the the Recent button is now remembered between sessions; you can press it and if you close the Propeller Tool, the next time you restart it, it will only show you the recent folders in the Folder List. This should speed up the startup time. If you need to see all other folders, you can press the Recent button again to update the Folder List display with all drives and folders.
In addition, I was able to rearrange some code to allow the tool to show itself before the Integrated Explorer is finished loading, so that if you had launched it via double-clicking on a *.spin file from Windows Explorer (for example), you could start reading the file even before the Tool is ready for your input.
As soon as possible, I will improve the responsiveness of the Propeller Tool even more to try to erradicate this startup-delay and a number of other issues.
Thank you.
Jeff,
I tried a few times to download it and got a ERROR 1335 Data Cab Corrupt Twice!
I had tried to download it as a file and got an error in the installer,so I tried directly! no go!
looks like your file has got munged!
regards Dennis
http://people.delphiforums.com/cocokiwi/Image/picture.jpg
Post Edited (cocokiwi) : 7/19/2006 12:43:51 PM GMT
I've seen the data cab corrupt issue a couple times (some kind of file download issue with web servers/clients.· It sounds like you got it downloaded and running, but I can't explain the corrupt file issues earlier.
Everyone else,
Thanks for the suggestions, I'll get to those as soon as I can.
--Jeff Martin
· Parallax, Inc.
The text in the source window is hard to read. Half the characters seem only half-width. I thought I saw a thread on how to change font, but am unable to find it at the mo.
Anyone point me there?
Robin
P.S. Propeller Tool 0.98.1, Windows 2003
Robin
I think the Tool is still under construction. One of the missing features is the preferences. I would imagine that this would solve your problem.
Keep in mind, it hasn't yet gone to version 1.00....
-Parsko
Just got to try it out @1600x1200 on one of the development machines, much better.
@800x600 in the server cupboard (where I seem to live
It's great to be able to compile without the propeller. The other controllers we use
have the compiler on-board, so I need access to the micro itself.
Robin
-Dan
We had tried that, but bigger or smaller cropped chars are...
This morning Windows died, so we had to reboot the server and presto!
Windows - got to love it?
Robin
Yeah windows is cute & mysterious, . . .· LIKE ROAD KILL!!
On the flipside, i concurr with the others, GOOD JOB HEROES OF PARALLAX! for the great support and devotion you've shown all of us, even the knuckle-heads! Thank you guys!
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
