Eagle Schematic Reference Design
Hello,
I've started up a reference design in eagle. Its using the full up version of the program so I don't know if the lite version can open it. I created the eeprom part and the prop part so that eagle users can create propeller schematics.
If anyone is looking for it to be posted I will - but right now I'll post pictures.
Kind Regards,
LucidGuppy
Kind Regards,
LucidGuppy
something smells like it's on fire
Thanks from all of us!
··· I have several "3 transistor programmer" PCBs, with the same schematic, you posted,·but they do not work very well. (The reset signal needs to be inverted for better performace) and if you use hyper terminal, it can ruin your voltage supply for RS232 level generating circuit.
·· A MAX3232 version works really nice (see PropStick sch.)
· Attila
I'll put in the max232, and invert the reset line.
Sorry for the wait.
-Guppy
It just won't create files beyond the double sided and half-Euro card limits.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Please poke holes in it - as it would help my designs.
I can tell you put a lot of work into this. It is just what I was hoping for. Once you feel it is ready, you should submit this to the Eagle library.
Any objections?
But there is the 78M33C 3.3 volt regulator.· It might save you some board space and soldering time.
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
1. If you drive the 3.3V regulator from 5V, make sure the dropout voltage on the 3.3V unit is at most 1.7V.
2. Be sure to use the right caps on both input and output. Some regulators — especially the low-dropout types — are very fussy about minimum capacitance and both minimum and maximum ESR (equivalent series resistance).
3. Some regulators (like the LM2940) are reverse battery protected. This is a huge plus in an experimental environment!
