Using Semaphore
I have two cogs that access the same memory, one running Spin the other Assembly.
Here is a code segment:
fifoSize is being use by both routines, but because the the assembly code takes three instructions to update the value, I was wondering if Semaphores should be use to lock out the other routine when one routine is using it.
If I do need to use semaphores, how do I go about inserting the LOCKNEW,·LOCKSET, LOCKCLR code in the assembly?
Thanks.
CON
FIFO_SIZE = 32
FIFO_MASK = FIFO_SIZE - 1
VAR
long fifoSize
long fifoHead
long fifoTail
long fifoBuff[noparse][[/noparse]FIFO_SIZE]
PUB Insert(val)
if (fifoSize < (FIFO_SIZE - 1))
fifoBuff[noparse][[/noparse]fifoHead] := val
fifoHead := (fifoHead + 1) & (FIFO_MASK)
fifoSize++
Dat
mov t1,par 'Point to fifoSize
rdlong fifo_size, t1
sub fifo_size, #1
wrlong fifo_size, t1 'update fifoSize--
t1 res 1
fifo_size res 1
Thanks.
If you want to use semaphores anyway, the instructions work the same in assembly as in SPIN with the previous value of the lock put in the carry flag (if wc is given). In this simple case, better to avoid them. You do need to access two values (read and write pointers) which are word values. Do not write them together as a long value! You can read them together if they're aligned on a long boundary. If the read routine is in assembly, you can put the read pointer first, get the values with one RDLONG, and update the read pointer with a WRWORD, both using the value in the PAR register.
In SPIN, declare the pointers as a long (say FifoPtrs) and access them with WORD[noparse][[/noparse]@FifoPtrs] for the read pointer and WORD[noparse][[/noparse]@FifoPtrs+2] for the write pointer.
Post Edited (Mike Green) : 7/31/2006 7:39:12 PM GMT
