Demo board and servos
Good morning to all,
I am the proud owner of a Prop demo board and a few servos. My experience is mostly in the software side of things so I am at a loss as to the proper way to attach some RC Servos to the demo board. The Servo32 code is just waiting for me to test it, once I can wire the darn things up.
I've looked at the source and researched the demo board's available pin outs - I'm guessing I can only drive up to 7 servos with the pins that are available on the board but how do I connect the signal, +, - leads to the servo?
Thanks for your help in advance,
A newbie robot builder.
Lee
Lee
I've tried the BOE-BOT chassis with the Propeller and set up some servo header pins on the breadboard. I tapped into the 6V battery pack wiring to get +6V for the servos directly (with an on/off switch). Works well.
