TV_text refresh
I have the attached program that is working awesome except for one thing. Note - it outputs to TV using TV_Text. It refreshes the ADC 10bit value on the first line of the TV. I want to overwrite that every time, which it does. Problems arises when I go above 3 digits (aka >1000) then back down to 3 digits (<1000), it leaves the 4th digit (it does this when it goes to two or one digit too). I can overcome this by clearing the screen, but then the same value appears to blink at a rate of roughly 5-10Hz in a diagonal manner. I know this is due to the clear screen.
Is there a way I can keep it from having the refresh/blinking effect?
-Parsko
BTW - I feel this is my first (real) object. Much thanks to folks here for answering my questions.
-Parsko
This can either be done by figuring out the value to be displayed and doing the padding, or you can just overwrite each time with 3 spaces at the origin of the number. If you do this·immediately before displaying the value, the blinking should be unnoticable.
Post Edited (Paul Baker) : 7/27/2006 10:45:52 PM GMT
I think I tried that and it didn't work. After having a night to sleep on it, I have determined, that using the existing objects and hardware, there is no diret route. You are right, I could "figure out" what the value is, then adjust accordingly. Not sure how fast that is though. Also not sure how fast I really need this to display right now either...
On another note:
"BS2.SHIFTIN" can be replaced by a "SERIN" command, right? I don't think it's a drag-n-drop situation, but it should work, right? I want to up the clock speed to get faster conversions...
-Parsko
Truly Understand the Fundamentals and the Path will be so much easier...
Notes:· This code would go into the TV_Text object file, not your application file and, up in the VAR section, add:
BYTE TempBuffer[noparse][[/noparse]30]
Hope this works.· As always, crits and comments on my code are welcome from all.
KK
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
Ok I looked at your code, and I see you are using the home command, this should've worked, you could try using backspace, though I dont know offhand what the behaviour of baskspacing when you at home position does, alternatively you can try to do the goto commands.
Post Edited (Paul Baker) : 7/28/2006 4:56:59 PM GMT
This blanks out just the left-over digits when the value displayed is shorter
If you want a routine that right justifies a value in a field of fixed size, try
But my code gives the option of left,center or right justification and width [noparse];)[/noparse]
Now I have to spend some time with the lady... I have been on such a role this week, I hate to quit now! grrrr.....
-Parsko
Nice solution Mike, quick and elegant.
