TV_text refresh
I have the attached program that is working awesome except for one thing. Note - it outputs to TV using TV_Text. It refreshes the ADC 10bit value on the first line of the TV. I want to overwrite that every time, which it does. Problems arises when I go above 3 digits (aka >1000) then back down to 3 digits (<1000), it leaves the 4th digit (it does this when it goes to two or one digit too). I can overcome this by clearing the screen, but then the same value appears to blink at a rate of roughly 5-10Hz in a diagonal manner. I know this is due to the clear screen.
Is there a way I can keep it from having the refresh/blinking effect?
-Parsko
BTW - I feel this is my first (real) object. Much thanks to folks here for answering my questions.
-Parsko
This can either be done by figuring out the value to be displayed and doing the padding, or you can just overwrite each time with 3 spaces at the origin of the number. If you do this·immediately before displaying the value, the blinking should be unnoticable.
Post Edited (Paul Baker) : 7/27/2006 10:45:52 PM GMT
I think I tried that and it didn't work. After having a night to sleep on it, I have determined, that using the existing objects and hardware, there is no diret route. You are right, I could "figure out" what the value is, then adjust accordingly. Not sure how fast that is though. Also not sure how fast I really need this to display right now either...
On another note:
"BS2.SHIFTIN" can be replaced by a "SERIN" command, right? I don't think it's a drag-n-drop situation, but it should work, right? I want to up the clock speed to get faster conversions...
-Parsko
Truly Understand the Fundamentals and the Path will be so much easier...
PUB JustifyDec(Value,Justify,Size, Filler) | NegFlag, Index, Counter, Offset, PIndex, HoldValue HoldValue := Value 'Hold the value for later resue NegFlag := false 'The Neg flag, needed for later usage as well Counter := 0 'Used to count the # of chars in the output PIndex := 0 'Used to build the output array IF Value < 0 'If it's a neg number -value 'make it a positive -HoldValue 'and make the hold value a positive NegFlag := true 'throw the neg flag for later usage Index := 1_000_000_000 'Max number of digits REPEAT 10 'Repeat the max number of digits IF Value => Index 'Counting values until the loop exits Counter++ RESULT~~ ELSEIF RESULT OR Index == 1 Counter++ Index /= 10 Value := HoldValue 'Reset the value (for later) IF Size <= Counter 'If the value is bigger then the size then just output it and exit Dec(Value) RETURN Offset := Size - Counter 'Determin the number of filler spaces needed IF Justify := 2 'If it's centered, Offset := Offset / 2 'half the number of filler spaces needed IF NegFlag 'If it's a negitive number, subtract 1 from the filler count Offset := Offset - 1 REPEAT Index FROM 0 TO 30 'Max size is 30, so for all 30 TempBuffer[noparse][[/noparse]Index] := 0 'set to null (str print routine uses a null terminated string...) IF (Justify := 1) OR (Justify := 2) 'Only if right or center do we add BEFORE the number REPEAT Index FROM 0 TO Offset 'And we only add the number of filler spaces needed TempBuffer[noparse][[/noparse]Index] := Filler 'by building the array with the filler char PIndex++ 'and incrementing our index into the output array Index := 1_000_000_000 'Reset the max number of digits (we recycle index all over...) IF NegFlag 'If it's a negitive number, add it into the output array TempBuffer[noparse][[/noparse]PIndex++] := "-" REPEAT 10 'This is a duplicate of the counting loop, only this time IF Value => Index 'we're outputing the actual values into the output array TempBuffer[noparse][[/noparse]PIndex++] := (value / Index + "0") Value //= Index RESULT~~ ELSEIF RESULT OR Index == 1 TempBuffer[noparse][[/noparse]Pindex++] := "0" Index /= 10 IF (Justify :=0) OR (Justify :=2) 'Only if it's left or center do we add AFTER the number REPEAT Index FROM 0 TO Offset 'adding only the number of filler spaces needed TempBuffer[noparse][[/noparse]Index] := Filler STR(TempBuffer) 'Now its a null terminated, justified string... use STR to output!Notes:· This code would go into the TV_Text object file, not your application file and, up in the VAR section, add:
BYTE TempBuffer[noparse][[/noparse]30]
Hope this works.· As always, crits and comments on my code are welcome from all.
KK
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
Ok I looked at your code, and I see you are using the home command, this should've worked, you could try using backspace, though I dont know offhand what the behaviour of baskspacing when you at home position does, alternatively you can try to do the goto commands.
Post Edited (Paul Baker) : 7/28/2006 4:56:59 PM GMT
txt.dec(x) repeat 3 txt.out(" ")This blanks out just the left-over digits when the value displayed is shorter
If you want a routine that right justifies a value in a field of fixed size, try
PUB decFixed(value,width) | i, p, f, a, b, c '' Print a decimal number of fixed width p := @a f~ if value < 0 -value byte[noparse][[/noparse]p++] := "-" i := 1_000_000_000 repeat 10 if value => i byte[noparse][[/noparse]p++] := value / i + "0" value //= i f~~ elseif f or i == 1 byte[noparse][[/noparse]p++] := "0" i /= 10 byte[noparse][[/noparse]p]~ i := strsize(@a) if i < width repeat width - i txt.out(" ") txt.str(@a)But my code gives the option of left,center or right justification and width [noparse];)[/noparse]
Now I have to spend some time with the lady... I have been on such a role this week, I hate to quit now! grrrr.....
-Parsko
Nice solution Mike, quick and elegant.
