Help or/and opinions
I have a real question this time. I am going into electonics and I am planning to buy a Homewok Board and the other supplies in a kit. Later on I will build a robot·using a propeller chip. I ... I·need help
·.·I...
! I want to build robotic legs that move like a spider's leg. What supplies do you think I need
? I will show you a little pencil animation later.
·.·I...
crustcrawler.com/products/nomad.php?prod=3
www.parallax.com/detail.asp?product_id=28023
I hope you get what i tried to draw [noparse];)[/noparse]
The school nerd
http://www.robotstore.com/store/product.asp?pid=254&catid=1550
<!--StartFragment -->
Also I'd suggest getting a prefabricated kit at first, simply for the documentation and example code to make it all work.
http://www.lynxmotion.com
http://www.servocity.com
Best of luck!
Matt
Bruce Bates
Anyway, maybe you can customize my cheap design. I had to drill like 5 holes per leg, but used all basic components from my local home depot.
For the leg I used an L brace (the kind that are made of tin and hold up shelves)
and attached the servos with a variety of braces I found in the hinges section (a "T" 3 little "L"s and a few bigger flat "L"s bent into shape)
and a hinge
I used pushrods and they're associated connectors from the local hobby shop.
It's not an easy feat trying to build legs from scratch. Mine took over 60 hours to completion and nothing is quite exact (drilled by hand with no vise). Hopefully they'll inspire you. It may be easier to do like some of the other members suggested and start out with some kits first, and/or maybe customize the kits to suit your needs.
I'll try to post some pics later when I get home.
---07/11/06 16:27 (-08:00 GMT) Uploaded 3 pics, and 1 zipped quicktime video. ---
Post Edited (Will__S) : 7/11/2006 11:28:05 PM GMT
http://freepatentsonline.com/5423708.pdf
- Stephen
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"The meaning of life, is to give life meaning" Unknown.
If you don't want that approach then check out servo control for RC Airplanes.
The only other thing you could do is try to pull up servo control code from the web. That will take some research and you will probably need to rewrite the code to fit, but its a starting point.
Post Edited By Moderator (Chris Savage (Parallax)) : 8/28/2006 3:46:17 AM GMT
Post Edited (scary_bot) : 8/6/2006 5:22:52 AM GMT
