Are we stuck without SPI interface
LoopyByteloose
PBasic has SHIFTIN and SHIFTOUT to provide support for SPI, but I cannot locate similar objects in Spin.
Is this something that will be forthcoming or should I be considering it a task that is up for grabs?
It seems everytime SPI is discuss, the topic shifts to I2C.· While I do like I2C, there are products that don't have a license for it and may never get one.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
SHIFTIN and SHIFTOUT are located within the BS2_Functions object.
There is even a SHIFTIN_SLV and a SHIFTOUT_SLV mode that is not part of PBasic. These
are SLAVE modes that basically work the same as SHIFTIN and SHIFTOUT, but the one
major difference is that in SLAVE mode they rely on an external clock..
Beau Schwabe
IC Layout Engineer
In theory, the SHIFTIN_SLV would work with the "ps/2 peripherals" you mention IF it were fast enough. The objects that
talk to the "ps/2 peripherals" are written in Assembly. There is no secret or conspiracy.
Beau Schwabe
IC Layout Engineer
I doubt they will let me load the propeller tool here.
And the old motherboard at home fried the other day.
I'll take your word for it.
$79 dollar motherboard·/ 5 bigmacs a week = 5 more months without buying a proppellar!
What I'm getting at ,Since I'm Propless for a while, is possible soldiering on a board that would give the propstick all the demoboards peripherals and only use a serial setup or two. leaving it with most of it's I/O untouched.
Sorry to hear about your conspiracyless situation, Everyone should have at least one!
I have been having trouble locating all the library items. It hadn't occured to me to look the BS2 compatablity objects. I guess I should load version 0.98 too.
I even began to ponder DIY in assembler, but I cannot figure out how to do it all. I know in theory how it is done with the SXes, for input the Carry bit is written to on each clock and then rotated unti one has a byte. But it seems that the same Write to Carry function isn't available.
I will enjoy reading the code to see how the Propeller differs. I can think of several other ways, but it all gets too technical and theoritical.
Now, I clearly noticed that the Object have a decription of items that are available within.
Obviously, I just wasn't observant and aware enough to locate these things. I guess I have to just keep looking into objects and reading code until I can see how it is managed. For some reason, I imagined that each low level object would be fairly standarized and in its own DOS file.
I am happy to see the Slave Modes too. It is hard for me to imagine the Propeller as being the slave component with so much utility. Currently I am trying to get on with a Master SPI application that would eventually have the Propeller provide Keyboard and Video management of a CANbus.
I can see the slave modes being useful for SYNCHRONOUS COMMUNICATION rather than ASYNCHRONOUS. In the real world this might apply to a Propeller
in the field running in RC mode where clock timing might not be that accurate. (Solar application using an RC mode clock to help conserve power?).
Beau Schwabe
IC Layout Engineer
