Looking for pliable (steel) wire for servo arm
I need to make a servo arm out of some thin yet somewhat stiff material that could be easily bent into shape. I am thinking steel wire, but where to get it? My project is giving a model car a convertible ragtop, and it seems to me the easiest way would be to have a flexible servo arm (wire) that could just be screwed onto a standard servo horn and have the cloth wrapped around it. Any ideas on the project or where to get steel wire? Thanks.
2)RC hobby shops?
3)Your local hardware store?
At the local Ace hardware store, usually toward the back where hobby brass, copper, and aluminum sheets are kept, you can find
steel, aluminum, and brass rods that would work for your application.
If you need a lot of material, Electric fence wire works nice for many applications such as this.
Beau Schwabe
IC Layout Engineer
They usually have a broad range of Piano-wire in the shop for just that purpose.
Electric fence wire?
I didn't know anyone still used single-strand wires for that anymore?
(Here we use plastic fibres of some kind, interwoven with metal strands. Easy to tie in knots, doesn't break and is very easy to see)
Don't visit my new website...
Piano wire can be so hard that it will damage wire cutters [noparse][[/noparse]chip the blades] and should be cut by notching with a file and bending at the notch. It comes in larger diameters for push rods, but it cannot easily be theaded. It can be hairy to bend.
Brass brazing rod is a wonderful item as it is stiff and doesn't rust. Try a welding supply as they sell it by the pound. Larger sizes can be threaded easily for push rods. Usually there are only 2 or 3 sizes available. Bending is reasonable.
Guitar strings are quite handy for robotics. The wire is stiff, but not as stiff as piano wire. The problem is that there are lots of sizes and some are covered with a brass winding. At times this may be useful [noparse][[/noparse]for soldering], at other times it may be too big.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
[noparse][[/noparse]code]
________
·········· ======= Servo
··········· |__
[noparse][[/noparse]/code]
Push the end through the servo-horn and it'll stay put.
You can also get special fittings that clasps around the wire and the horn so that you only need a single 90degree bend.
Also, the RC-hobby stores often have threaded rods, too.
Those stores can be a bit pricey sometimes, but they have a lot of neat stuff...
······ Joe Fishback
-Robots are my friends-
kelvin
