Freescale Announces MRAM
Folks -
It looks like Freescale is going to try to give Ramtron a run for its money in the field of magneto-resistive memory. It will be interesting to see if there are any patent infringements involved, with some of Freescale's rather bold claims of being "first":
http://news.zdnet.com/2100-9584_22-6092242.html?tag=nl.e589
Bruce Bates
<!--StartFragment -->
Bruce Bates
From the sound of it, the Motorola (oops, Freescale) ram actually uses magnetic states to store the 1s and 0s.· Like the old magnetic core memory, except I'm thinking it is non destructive read out, since they use the change in resistance of some element in the cell that responds to magnetic fields in an absolute sense, not just to a change in field strength.
I wonder if they have to build a shield into the package...
And I wonder how much power they consume to change a bit compared to FRAM?
More competition means lower prices down the line, unless one company or the other starves to death.
MRC
through some other company or a specialized division within the company.· We gave them the size and dimensions of the
memory structure that we wanted in the application, and in return during the fabrication process the memory block was
applied.· The·main reason·is because in most processes NV memory breaks many of the standard layout rules and requires
special·handling of additional layers not available·within the custom layout environment.
Beau Schwabe
IC Layout Engineer
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Hailed as "the most significant memory invention of the decade", magnetoresistive random-access memory or Mram could one day overthrow hard discs and flash memory.
A couple of weeks ago a company called Freescale announced that it had produced a working Mram chip which can hold four-megabits, that is about half a megabyte.
