UDP pink
hello,
i wrote a testprogram for communicate between SX and Pink. I send a UDP string out of the pink with use of the instructions that are needed, see manual pink.
Where can i,or how can i read out that string in the UDPterm (how do i have to set that up?)
Kurt
Kurt
http://forums.parallax.com/showthread.php?p=568653
Connect the SX to the Pink using TTL serial connection.
Connect the Pink to your PC using ethernet connection.
regards peter
