USB disconnect
With the Demo board connected to USB and running, if you use the On/Off switch to turn the board Off, do you have to click on the "Safely Remove" icon first?· I know you have to click on that icon if you are removing the USB connection from the PC.
Sid
Sid
Chip Gracey
Post Edited (Chip Gracey (Parallax)) : 7/15/2006 6:35:36 PM GMT
Mike, the Demo board doesn't use a converter.· It plugs straight into the USB port.
Sid
Chip, you're basically right in that the "owner" of the USB connection to a storage class device like a thumb drive is the file system of the OS and it usually wants to know if the device is about to be removed because some write buffers might not have been written to the device yet. For other devices, it depends on how they're used and who's using them (like how the driver is implemented). I've seen 'Don't Do That!!' messages from both Windows and the Mac OS when I didn't expect them for non-storage devices including serial-USB ports. Usually it's if the device has been opened by some program and not yet closed. On the other hand, I've often pulled non-storage USB devices with nary a peep. The Mac seems to be better behaved than Windows in this regard, but "your mileage may vary". It probably has to do with who wrote the driver and how well they did it.
