looking for a soldering iron ($50-100)
Hey guys,
I've been using those cheap $10 irons, and was wondering if the more expensive ones were actually worth it. I saw a few at Fry's Electronics Store, and noticed the higher end irons had temperature control. How essential is this feature? At the moment, I only solder DIP.
Matt
Matt
In my opinion temp. control is a very good idea. Another feature that you should consider is an iron with different size tips. A good soldering station can be used for anything from surface mount devices up to transformer terminals. Picking the right temperature setting for your iron can save you a lot of tips also.
Lee
Here is one source that you can check out:
www.techni-tool.com
They also were very knowledgeable when I've talked to them on the phone. Not that I'm pushing them, just happened to have really good luck there for my purchases.
stand back! I have a slide rule and I know how to use it!
· If that's a bit much, I recommend the Weller WP25 (< $50).· I've had mine for >10yrs and have never had to change the tip.
··It's important·that you·never solder without a damp sponge at the ready, keep your tip tinned from the start, and also buy a tip conditioner to clean it up from time to time.· [noparse][[/noparse]Unless you like buying and changing tips -- and making crummy solder joints.· Mmmm, cold solder; my favorite, ooooo!]
John R.
8 + 8 = 10
I'm just 10 people short of a threesome!!
[url=mailto:shane [shane@howardelectronics.com]]mailto:shane [noparse][[/noparse]shane@howardelectronics.com][/url]
I have also send mail directly to that address.
John R.
8 + 8 = 10
Thanks!
I also bought my· Xytronic from Howard and the Contact Person was Shane he·is a very help full person
I like Soldering Station that i have the 137 EDS Model
And also bought the Solder Holder for the One Pound· Roll that is best thing that i have seen yet···
[url=mailto:shane]mailto:shane[/url] [noparse][[/noparse]shane@howardelectronics.com]
Sam
