PropSTICK won't run! — Parallax Forums
HarleyHarley Posts: 997
edited 2006-07-12 15:54 in Propeller 1
Received my PropSTICK yesterday, stuffed it and soldered per kit instructions.
Today I do the power checkout. All appears OK.
I measured the draw prior to installing the Propeller IC; about 650 uA. And with the IC installed, draw would go up to about 4-5 ma momentarily after Reset switch pressed.
I note the DB9 shows pin 4 is wired. The cable has been in use for months and work OK. Any clues what to check on?
Harley Shanko
h.a.s. designn
    edited 2006-07-12 03:06
    Harley,
    Are you sure that pin 4 is wired straight through your cable? Some cables carry only pins 2, 3, and 5. Without pin 4, the cable may work fine with other apps, but it won't work with the Propeller.
  • HarleyHarley Posts: 997
    edited 2006-07-12 05:31
    Hi Phil,
    Yes, I buzzed out the cable after sending my last message. All 9 pins are wired, pin-n of one connector to pin-n of the other.
    That's what bothered me. I sure expected it to communicate. I examined the soldering; didn't see any shorts. Maybe it would be worth buzzing adjacent pins to ensure none are shorted by a thin solder bridge. Ma
  • Ken GraceyKen Gracey Posts: 7,415
    edited 2006-07-12 06:06
    Okay, I shouldn't make any assumptions so I'll ask this anyway.
    Is the serial port on the PC functional? Can you check it with another device just to make sure? Might be good to rule out the PC serial port (and the cable) as problems, and narrow this down a bit. I know that when I haven't used my serial ports in a while they kinda vaporize or I get locked out, especially if I've been working with GPS or adding FTDI Virtual COM ports.
  • SawmillerSawmiller Posts: 276
    edited 2006-07-12 10:29
    did you check for 3.3 v from the propstick ?
    dan
    edited 2006-07-12 14:53
    PropSTICK now gives the "Propeller chip version 1 found on COM1"
    I removed the Propeller from the socket, cleaned the flux from the board, buzzed out all the adjacent pins (thought I found a short, but it was the pin 9 and 10 connected to ground), examined it with a 5x magnifier, and plugged it back into the solderless proto board and this time it worked. I did scrape a bit where it looked like some flux was still between adjacent pins; maybe conductive crud.
    Now, progress FORWARD. Thanks for all the suggestions. Sorry to take anyone's time on this mystery.
    Harley Shanko
    h.a.s. designn
    ....and, pressing F11 loaded the Prop, HyperTerminal showed the message
    "Alive... It's alive!..... IT'S ALIVE!!"
    "And, away we go!" (Jackie Gleason)
    Harley Shanko
    h.a.s. designn
