How to make SX/B Template default
Hello,
I just installed the latest version of the SX-Key . Whenever I go to open a blank sx/b page it opens a programming template·from a previous version. How do I set the default blank page to be the latest programmng template?
BTW great work on the SX/B v1.50.01
thanks
MikeS
thanks
MikeS
I think you just put the template you want into the C:\Program Files\Parallax Inc\SX-Key v3.2\Templates directory as "template.sxb".
Bean
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I'm a man, but I can change, if I have to, I guess" The Red Green Show
I had to rename template.sxb to blank.sxb in the C:\Program Files\Parallax Inc\SX-Key v3.2\Templates directory.
