help!!!!! roborealm with basic stamp 2
hello
i am making a project where i want to control 2 servos via the pc in real time but i dont have a servo controller.
can i move them without the module?
enlight me
sorry for my bad english
lazyman from greece
p.s. i am despared
FOTIS DASKALAKIS-GREECE-
Post Edited (lazyman[noparse][[/noparse]GR]) : 7/9/2006 7:13:05 PM GMT
enlight me
lazyman from greece
p.s. i am despared
Are you:
1) trying to use only your PC and the servos, with no other electronics
or are you:
2) trying to interface your PC to a BS2 that is connected to the servos?
If the answer is 1, you'll need an appropriate interface cable (you'll probably need to build one), and some application (you might have to write one) that allows for servo communications.
If the answer is 2, you can connect your servos to a BS2 module, and write a program that does the following:
1. Listens for input from the PC (easiest would likely be serial port)
2. Receives and parses input from PC
3. Performs some task based on PC commands
4. Goes back to Step 1
Also, just to let you know, when posting questions, it's easier for people to help when you give as much detail as possible. Let people know what parts/components you have, and what exactly you are trying to accomplish.
i want to control a camera via a laptop.
i want to move it left-right down-up
the program it may have 2 selections.
1
fully automatic. use of roborealm to lock on target (can i·use external variables to the pbasic program like·roborealm·?·)
2
manual (at first step with serial cable)
at last step with rf communication.
ps. can i control more than 2 servos with basic stamp using bread board?
thanx for the answers
Post Edited (lazyman[noparse][[/noparse]GR]) : 7/10/2006 3:10:37 PM GMT
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
that can be usefull for me
thanx
Let us know if you have any more questions.
STeven.
http://www.roborealm.com/
·· A better suggestion for connection to a PC is Stock# 28823, since it is USB, whereas 28023 would need additional circuitry to connect to a PC Serial Port.· The USB Version communicates serially just as the 28023 through a VCP Driver installed on the PC.· Please see the documentation for more information.· Take care.
Chris Savage
csavage@parallax.com
