Congrats Bean on your product listing at Sparkfun
I was checking out the new products at Sparkfun, and lo and behold I see your video module and LED module availible through them. Congrats!
Life is one giant teacup ride.
I bought a bunch from Bean earlier as I had seen a competator in Nuts & Volts asking $20US a piece for similar devices!
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
· By the way, I have a couple hundred displays that are scratched really bad (but still work fine), if anyone wants some, I will give you DOUBLE the quantity. Just order from www.hc4led.com ·and put a note that you want "double quantity of scratched displays".
Terry Hitt
Hitt Consulting
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
Post Edited (Bean (Hitt Consulting)) : 6/16/2006 5:15:10 PM GMT
·· It might make it more worth it for some people if they knew that using a red filter lens should make the scratches disappear.· This could be just some Red translucent plexiglass.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Ryan
Ryan Clarke
RClarke@Parallax.com
Do you have a source for inexpensive red plexiglass? I searched for it, but probably used the wrong keywords. I kept coming up with photo filters ($$$$).
Chris Savage
Hmmmm, I may have to try that...
Bean.
I'd thought of the transparency idea, but since most inkjet printers are CMYK, the red would have to be a mixture of colors. I wasn't sure how even it would end up That, and not having any transparency film kept me from trying it.
Years ago, I remember buying report covers that had transparent red, blue, yellow? covers. I checked the usual office megastores and I can't find anything transparent except clear. That stuff was thick enough to work in this application, but thin enough that it could be cut with scissors.
Is there such a thing as transparent paint?
Also, I found a guy on e-bay selling transparent red plexiglass. The prices aren't too bad, but the shipping (Texas -> Maryland) is almost as much as the plastic.
cgi.ebay.com/ebaymotors/Transparent-Red-Plastic-with-adhesive-8-x-12-sheet_W0QQcmdZViewItemQQcategoryZ42613QQitemZ7983151282QQrdZ1QQsspagenameZWD1V
This seems to be what you're looking for. Hope this helps.
kenjj
PS I can't STAND those d*mn dancing icons in the margin!!!!!!!!!!!!!!!!!
kenjj
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
Might not be worth the cost of the sandpaper and polish though.
Parts Express has some colored gels for stage lighting that might work as a display filter.
www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=244-106
- Rick
Automotive shops provide at least two grades of polishing compound for removing scratches from your painted exterior.
There are a fine and a course. I believe that the red is the Fine and will polish acrylic plastic quite nicely.
Ask for Dupont Polishing Compound.
You can even burnish areas with a Q-tip.
There is a lot of translucent 'Smoke colored' plexiglass available that will do as well or better than the Red gel stuff as it is quite thick and stiff. It won't wrinkle or move around on you. Just glue or bolt in place. Google 'smoke colored transparent plastic'
I formulate OEM wood finishes for a living and some of these are nitrocellulose based lacquers that are used on furniture, musical instruments and such that must be rubbed to a smooth, high gloss appearance.
Typically the first "cut" is with 400-600 grit paper used with a lubricant (often just water), this is to even out the normal "orange peel" look you get with spray applied finishes.
Anyway, its probably not worth the effort, a red or smoke tinted filter will hide the scratches just fine.
BTW, that Ebay seller with the red vinyl sheets also has them without the adhesive in their Ebay store.
I'm not sure the adhesive backed type is what you want for this application.
- Rick
Heh Bean, did you ever try to use the liquid scratch repair for Cd's, or plastic lens glasses???
I'll bet the cd repair liquid would fix em real good....
I have picked up on EBay several different colors/shades/thicjnesses of plexiglass sheets for making filters on flashlights, REAL cheaply too!!
Also, an application of liquid superglue left on to dry should fill in the cracks, but I would try 1st....
Bob
It is a digital litho press that works like a laser printer.
It uses plastic ink and prints perfect translucent C M Y K on Lexan, and clear polycarb materials up to 60mm thickness.
I can even have a full color picture backed with white in 230 line screen resolution on the part.
So let me know if you want free samples of an Idea you have. Maximum size is 12 x 18 inches.
Price about $3.00 per 12 x 18 inch in small quantitys.
We can die cut to shape, as well as place pressure sensitive adheasive.
Question for Bean, Have you sourced the 1W Luxeon LED. (Clones) I am looking for quantitys in the hundreds. I have bought from http://www.hebeiltd.com.cn/?p=z.pricelist.led.diode
Think outside the BOX!
Have you looked at buying the actual Luxeons from the Future Electronics web site (http://www.lumileds.com/products/rd_order.cfm)?· It looks to me that their pricing is better.
Chris I.
http://www.misterart.com/store/view.cfm?store=001&group_id=656
About $8 for a 30"x40" sheet.
Rubylith® is a red masking film, which is suited for use with orthochromatic films. Rubylith® is safe for use with camera speed darkroom films as well as indirect gelatin stencil films and diazo, diazo acrylic, or SBQ sensitized stencil films or emulsions. Rubylith® is primarily used in the camera and plate making operations for offset lithography, flexography, gravure, and screen processes where orthochromatic films and plates are used.
Rubylith® RM3 is a high tack ruby film coated onto 300-gauge polyester.
It's thin but strong and available from dealers all over the country.
I just mounted my project inside one of these, but I suppose they could be cut up to make filters.
