_clkfreq for Servo32 object
MacGeek117
Will the servo32 object run at _clkfreq = 5_000_000? The demo has it running at 4MHz.
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
"Will the servo32 object run at _clkfreq = 5_000_000"
Yes, I believe that is why I put a note in the software to check against whatever you would be using.
I just happened to have a bunch of 4MHz laying around that I grabbed and was developing this object with.
The important thing, because the servo object IS time critical, is that you just need to specify what you
will be using. Other than that it doesn’t care one way or the other.
Beau Schwabe
IC Layout Engineer
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
