USB hookup problem — Parallax Forums
USB hookup problem
MachineMonkeyMachineMonkey Posts: 30
edited 2006-07-04 14:45 in Propeller 1
OK...
I hook up power and USB, I throw the switch, lights come on, I connect output to aTV, a low-res graphic show is displayed automatically, so far so good.
Then I load a program and compile it and the darned program tells me there is no Prop on any COM port.
Well, duh. It's on the USB hub.
Question: How do I inform the Prop tool its looking at the wrong bus?
Kalo
Failure is not the only punishment for laziness; there is also the success of others.
- Jules Renard
  • CJCJ Posts: 470
    edited 2006-07-04 11:24
    sounds like you need to install the ftdi drivers
    Who says you have to have knowledge to use it?
    I've killed a fly with my bare mind.
  • MachineMonkeyMachineMonkey Posts: 30
    That did it.
    Thanks!
    - K
    - Jules Renard
