variable voltage regulator
Hello,
I'm using a variable voltage regulator to take·5v down to 3.3v. Every thing is hooked up properly and the voltage adjusts appropriately but when I hook the regulator up to·the transciever that it is powering my voltage drops to 1.24v and the regulator is no longer adjustable. As soon as·I unhook·it from the transciever it becomes adjustable again. Any advice?
So you just cannot use it to get a stable 3.3volts.
I suppose an LM350 or LM317 have a similar dropout limitation regardless of their being adjustible. Try 6 volts and see if you can get a stable output.
You would have to be using a low dropout regulator such as an LM2940-3.3 that has a dropout of 0.5volts above the regulated voltage. This would make a whole lot more sense.
Secondly, the third wire on the regulator senses the differences around a set voltage of 1.25volts [noparse][[/noparse]maybe you read 1.24, but that is certainly in that ballpark]. Seems to me that it is likely that nothing is wrong with the regulator, just the design.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
