Getting started with Propeller video output... — Parallax Forums
iam7805iam7805 Posts: 14
edited 2006-07-01 18:35 in Propeller 1
Hi guys,
I'm getting started with using the Propeller chip. Luckily, the Spin language is based on BASIC which is great, because I already know BASIC quite well.smilewinkgrin.gif
It's confusing me how to output video to a TV though. I read through the manuals and the comments in the TV.spin and Graphics.spin files, and was still confused on how to do this.
So, could anybody give me a straight-forward guide on how to output graphics and text? This Propeller seems very promising for my project, now to learn how to use it. tongue.gif
iam7805
    edited 2006-07-01 03:45
    Start with the demo programs that include some kind of tv output (like tv_text_demo). Once you have those working unchanged, you can modify them to suit your purposes. If you have the Demo Board, you have all the hardware you need. If you have a PropStick or just the Propellor chip, you'll need to attach the 3 or 4 resistors needed for the D/A conversion. Look at the Demo Board schematic for the values and how they're connected. The demo programs mostly assume you want to output video rather than a tv broadcast signal. Doing video is simpler since you don't have to change anything.
  • iam7805iam7805 Posts: 14
    edited 2006-07-01 18:17
    Ok, would this work the way I want (display Hello World on TV)?
    ' Hello World program
    ' Written by iam7805
    ' Required files:
    ' hello world.spin (this file)
    ' tv_text.spin
    ' tv.spin
    VAR
       byte loop
    OBJ
       textdisplay : "tv_text"
    PUB start
       textdisplay.start (12)    ' start display, base pin 12
    PUB message
       textdisplay.out($48)      ' H
       textdisplay.out($65)      ' e
       textdisplay.out($6C)      ' l
       textdisplay.out($6F)      ' o
       textdisplay.out($20)      ' <space>
       textdisplay.out($57)      ' W
       textdisplay.out($6f)      ' o
       textdisplay.out($72)      ' r
       textdisplay.out($64)      ' d
    PUB stop
       loop := 0
    REPEAT
       UNTIL loop := 1           ' Spin doesn't have Do...Loop
    (The reason i'm asking is because I don't actually have a Propeller yet)
    edited 2006-07-01 18:33
    1) PUB and PRI mark the beginning of a subroutine. They're not labels in the way you might expect from Stamp Basic.
    2) There are some shortcuts:
    CON
    SetX = 10
    SetY = 11
    VAR
    long count
    OBJ
    PUB Main
    textdisplay.start(12)
    textdisplay.str(string("Hello World"))
    repeat count from 1 to 1000
    waitcnt(80_000_000 + cnt) ' waits one second
    textdisplay.str(string(SetX,2,SetY,2))
    textdisplay.dec(count)
    Note that this will put out a video signal, not a broadcast signal (on some tv channel). To do this, you have
    to modify the tv_text object. Attached is a modified version of tv_text. Since the pins for the tv D/A have
    to be in groups of 4 (as far as the program is concerned), I use the lower 2 bits of the pin number to specify
    the tv channel to be used. If the bits are zero, color, progressive scan video is produced. If the bits are 1 through 3, TV channels
    2 through 4 are used. For TV, I've disabled color and used interlaced mode for a better display. I recommend
    using channel 3. Because of how the RF is produced, there's more static if channels 2 or 4 are used.
    Oops ... I forgot about the stripping of indenting in the standard message box. Please correct. Everything except the CON, VAR, OBJ, and PUB should be indented once and the stuff after the repeat statement should be indented twice.
