Best Method to BLANK screen via Ethernet??
I am trying to find a way to remotely shut down a VGA connection between an XBOX 360 and an HDTV. This would be for pay for play type of application. User runs out of time, I want a remote computer to send a signal to a box that cuts the display signal off.
Anyone heard of something that can do this or give me direction on a VGA cut off circuit? I can add the ethernet control part myself if I have a VGA cutoff circuit.
Matt
Matt
Chris Savage
Parallax Tech Support
csavage@parallax.com
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
This solution would not require any modification to any of the involved equipment and it pretty much plug-and-play.
I wouldn't connect that if I were you...
You can't control them with a string....you have to actually log in to them and select the port you want to change and then affect the changes.
Also, if this is something that resides at a persons residence....they could just unplug from that unit and plug in to their wall! :S
Steve
I still would be interested though in understanding how to cut VGA signal. I have also looked for something that does overlay on HDTV (using component video) and have found NOTHING. Something like the X-BOB is all I can find and all video overlay I have foudn is for composite video only. Is it really expensive or just really hard to create overlay on component video signals??
- Matt
You could use a Propellor Demo Board to generate the VGA for the second computer. You wouldn't even need the "pushbutton" input. The switchbox has a primary source and secondary source and switches to the secondary source if the primary one is off. Just have the Propellor turn off its VGA output when you want the game to appear and turn it on (with a message, even a fixed graphic) when the game is over.
Set up a stamp to control a few of these and you have a computer send the serial data to the stamp that it then interprets and flashes a beacon to let the user know they're going to run out of time. When the time elapses then trip a relay to cut the power....get one of Bean's video overlay modules and drop a message saying "GOODBYE" (of course this would force you to use the composite video (not the Y,Pr,Pb).
You could even get mean and drop the relay to their controller and force them to watch their character die!
Steve
String? Did I imply that in my post? Of course this would be controlled via a logged-in session, either Telnet or via the built-in web server.
idleup actually has a lot of control over the physical installation of the equipment. I understood that from his initial description of the application that this was going to be a game center so that implies that all the critical connections are protected, either because they're tucked behind covers and/or glued/bolted onto the equipment so that casual disconnection could not be done without an attendant or desk clerk noticing the customer mucking about the equipment.
I like Mike G's idea about using a Stamp to control a KVM to switch from the game console's VGA to a blank screen. You could actually have a single PC or dedicated black generator feeding into a VGA distribution amplifier and from that supply the "blank" VGA to the KVMs.
You know more about the propeller demo board than I do but it doesnt looks like it can handle HDTV component output... is that true or false?
- Matt
