Cant debug with SX-Key v3.10
When I chose the 'Debug' option from the menu, the program compiles and downloads to the SX28 just fine. But when the debug windows come up, it just shows a status of Running, and the Step buttons are all disabled. The code window has the Reset command highlighted in the code, and never moves. The program runs fine when I choose just the 'Run' option. What all can cause this? Could it be the serial port on the PC?
My setup seems to work fine except for the debug part. Any ideas are appreciated.
Can you post your code ?
What frequency are you clocking the SX at ?
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I reject my reality, and substitute yours." NOT Mythbusters
And i'm clocking at 10Mhz. This code just blinks a bank of 4 LEDs. Nothing special.
Thanks.
I had a similar problem earlier with my laptop...
Have you tried the infamouse FIFO buffers ???
http://forums.parallax.com/forums/default.aspx?f=7&m=130333
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Bean.
Bean, no, just a serial cable to the SXKEY directly.
·· the crystal or resonator wouldn't be plugged in between the computer and the SX-Key, it would be plugged into the OSC pins on the SX.· If you have the SX Tech Board there is a socket for it.· Do you have one installed?
Chris Savage
Parallax Tech Support
csavage@parallax.com
BTW: I'm using a kit from Andre Lamothe that includes the SX28, breadboard and the SXKEY.
And it programs and runs just fine, its just the debug option that doesn't work at all. Also, I'm using Windows XP.
Any other ideas??
I have done it twice already.
If you put voltage onto one of the oscillator inputs of the SX key it will break in exactly the way you describe.
It will program and read but debug just says "running" and can't do anything else.
If you plug in the SX key so that only 3 of the header pins go into the socket this will happen.
I wonder if this wire is hot...
Have you tried a very simple·program to see if you can get that to step through? I know that I have had some programs that were doing exactly what you have described, my SX-key was still good.
Thanks for all the suggestions.
more than once, I have attached the SX-Key the wrong way by mistake without frying it. Both OSC pins have resistors in series on the SX-Key, protecting the on-board SX20's port pins to a certain extent. When you plug the SX-Key in reversed orientation, the OSC1 pin goes to GND, the OSC2 pin to Vdd, and the SX-Key`s Vdd and Vss pins are connected to the target device's OSC1 and OSC2 pins. This means that the components on the SX-Key can never "see" a wrong polarity on the power supply lines. So according to my experiences, electrostatic discharges are the most common causes for frying the SX-Key.
When you can write, read and run with an SX-Key, the SX20 port pins controlling the target's OSC1 and OSC2 pins must be ok as both are needed for these operations. This also confirms that the Vpp generator on the SX-Key works (otherwise you could not program a device), and the variable clock also works, or you could not run the target.
On the other hand, for debugging, the same two port pins pins are used, so when you can read write the device, the communication between the SX-Key and the target should also work for debugging.
Maybe, this is a stupid suggestion:
Did you make sure that you have programmed the target for debugging, i.e. by selecting Run - Debug from the SX-Key IDE? When you have programmed the target using Run - Program, and then start the debugger via Run - Debug (reenter), it won't debug, and also show "Running" instead.
Greetings from Germany,
G
I have only used Run - Debug. I don't think I've tried the Run - Debug (reenter).
Could it be the version of the SXKEY IDE? The kit I have came with the 3.0 version, but I reformatted the computer that its connected to and just downloaded 3.1 from the Website.
I'm also using the most recent version of the SX-Key IDE here w/o problems, so I don't think that this is the cause for your problem.
G
If you don't believe me then try it yourself.
It will program, but if you try to debug it says "running" and that's all it does.
ok - now I got you, and I believe you w/o trying to fry an SX-Key myself
G
