Clock/Timer program in SX-Key v3.10 won't compile.
I've just gotten the $99·SX-Key package and I'm having a lot of fun with it, but I've run into one snag.· I'm trying to compile the Clock/Timer program that is found in the "Help/SX/B Help/Example Projects" directory and it won't work.· I get this error:
clock-timer01.SXB[noparse][[/noparse]116] Line 116, Error 8, Pass 1: INVALID PARAMETER "DigMap"
Line 116 is in this group, in the line that·states "READ DigMap + digPntr, DigCtrl···· 'update digit control"
Update_Segs:
· Segs = %00000000····························· ' blank segments
· READ DigMap + digPntr, DigCtrl··············· ' update digit control
· Segs = display(digPntr)······················ ' output new segments
DigMap·appears about 24 lines down, as a label for some data statements:
DigMap:········································ ' digit select map
· DATA· %11111110
· DATA· %11111101
· DATA· %11111011
· DATA· %11110111
Does anybody have any idea why I get this error?
Update_Segs:
· DATA· %11111110
· DATA· %11111101
· DATA· %11111011
· DATA· %11110111
You need to either move the "DigMap" label AND data to a place before it's referenced (like right after the PROGRAM line).
Or download SX/B version 1.42.01 from the forum, unzip it, and put the overwrite the files in C:\Program Files\Parallax Inc\SX-Key v3.1\Compilers\SXB".
Let us know if that fixes it.
[noparse][[/noparse]edit] Here is a direct link to the update http://forums.parallax.com/attachment.php?attachmentid=0
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I reject my reality, and substitute yours." NOT Mythbusters
I'm rapidly falling in love with the SX chips and SX BASIC.
Wait until the next release that has WORD variables...
Bean.
Where can I find more information???
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Be patient, it will be worth it.
Bean.
Post Edited (Bean (Hitt Consulting)) : 6/29/2006 10:29:52 PM GMT
You learn something new every day...
I sure wish them the best and I guess Parallax is super busy by now...
Anyway, I'm still learning this version of SX/B so I'm really not in a hurry...
Experience level:
/Bamse
