TLC555 Timer
what is it good for, i know everyone told me to get one for my IR Circuit but what can i use it for? and hows it hooked up... these schematics are very hard to read... are there any tutorials on reading some of these difficult schematics? thanks
http://www.uoguelph.ca/~antoon/
Hope this helps.
There are two configurations for a '555':
As an oscillator, it is a frequency source (could be fixed or made variable.)
As a "one-shot" you can use it as a source of controlled, repeatable·pulse-width (which can also be fixed or variable.)
With one of each you could control a servo: the oscillator would be set at the refresh rate (50Hz), triggering the "one-shot" whose resulting output pulse-width would determine the servo direction/position and speed (depending whether standard or continuous servo.)
In my current project, I use the circuit to drive 4 IR LEDs; this frees pins and processing on the Stamp for other purposes.
Once wired and working, you need only read your receivers-- the IR output is managed by the 555. Try Googling 555 tutorial for more info--it’s a very versatile chip with a long history; there is a virtual ton of info out there. How to read and respond to reflected IR is covered , I think, in Parallax's robotics text. Stay active here, someone will list the appropriate Parallax application notes and texts if you require more help.
Here is a section that covers the 555 timer.·
http://www.play-hookey.com/digital/timer_555.html
Most of the IC's and parts on the website can be ordered from·http://www.futurlec.com.
I hope it helps!·
Matt
