Datatransfer Propeller->PC via USB — Parallax Forums
GuentherGuenther Posts: 1
edited 2006-06-26 15:47 in Propeller 1
Hi,
Ist it possible to send data to a PC via the USB-Programming-Interface? What do I have to do? Just listen via terminal for data arriving at a serial port?
And what is the maximum resolution of the vga-stuff?
Thanks.
Guenther
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2006-06-26 14:48
    Look at what COM port is being assigned to the USB. From there use that as if you were speaking to a standard COM port in your PC software.
    Beau Schwabe
    IC Layout Engineer
  • GoogGoog Posts: 65
    Take a look at my thread on the Commodore 64 Emulator... we developed a VB program (and SPIN code) to interact between the demo board and the PC. The VB program acts like a large memory space for use by the propeller board. I've been using it to store 64K of memory since I can't have that on-board without extra hardware. It works great!
    Thread here:
    http://forums.parallax.com/forums/default.aspx?f=25&m=130455
    Goog
    Doing my part to keep the Commodore 64 alive!
    http://www.commodorestuff.com
