Code request
I am trying to read RPM from my car. Byt i cant get things to work with my bs2.
I juse COUNT on pin 0. But the funny is i get 0HZ wen nothing is connected, but if a just put a wier in pin 0 and the other end in the air and play with it i can get like 3000hz
And from the car i jusing this
· "Spolen" -- what's that?· The coil primary?· The input to the ignition coil is going to be spikes (the output, too), not square-waves.·
· See what happens without the LPF (or try a lower value of C; 2200pF, 1000pF.)
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=1075&highlight=
Think outside the BOX!
