newbie ? - power supply for boe/bs2
Just getting started and cautious.· Double checking that the Sceptre 9V wall wart is OK to use.· Mine is 16V+ with no load, and 14V+ with the boe powered up but not running anything.
Doug
Doug
This keeps us guessing if something is going to be damaged. LCDs are most often the first to be damaged.
You could put a parallel load on it [noparse][[/noparse]like a 5 watt resistor at 30 ohms for a 300ma load], but you have to be sure that the wallwart can power both [noparse][[/noparse]like 500ma or more]. Re-measure with the parallel load connected. You might find you have 9 volts.
Alternatively, you can just put a 7809 to 'pre-regulate' down to a steady 9 volts. I do this so that I don't have to worry about all that math again and again as I hook up different things.
Parallax is now providing +7.5 wallwarts because this has been a big headache.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Doug
Thanks again,
Doug
The recommendation chart·should suffice as the final arbiter.· If it matches up (Stamp and board) then it's OK.
Post Edited (PJ Allen) : 6/24/2006 9:33:28 PM GMT
You should use a PDF for the EXACT regulator that you purchase. Google is your friend. Sometimes we go to a store and buy something that is a bit different that the part we ask for. There can be small differences in how they are wired or what values of capacitors are optimal [noparse][[/noparse]I have some strange 3.3volt regulators here that require 100uf, but most 78xx use only 10uf].
Some people think that bigger capacitors on the regulators always improve the output, but there are situations that over 10uf can actually damage the regulator if you don't add protection diodes. It seems that when you shut down, the capacitor might discharge backwards through the regulator!
I GUESS maybe the white wire is negative (or maybe positive) -- BUT don't trust me. Always check your polarity with a meter. Check several times before you power up anything of value.
Both memory and guesses are the source of a lot of damage. I check everytime. This is especially important with all power connections as a reversed polarity is likely to do significant damage. Years ago, electronic standards were gospel, but these days you might get an odd one.
Reversed polarity might not immediately damage a BS because of the quality of the regulator on board, but it does immediate harm to ICs and LCDs. One reversal and a $30 LCD is garbage.
Post Edited (Kramer) : 6/25/2006 11:59:30 AM GMT
