Boe Bot based Inverted Pendulum
I built this using Boe-Bot parts and two QTI line followers. The chasis is a cardboard box I had laying around my desk and the whole thing is held together by electric tape. Right now it kind of works, it cans stay up for about 30-45 seconds on a good run, I think my main problem lays in the servos not being powerful or quick enough to compensate for the weight shift. I attached my code at the bottem if anyone else wants to take a stab at it.
Post Edited (Cheeto) : 6/23/2006 8:03:14 PM GMT
'{$STAMP BS2}
'{$PBASIC 2.5}
pos1 VAR Word 'Pos from RCTime
pos1_old VAR Word 'Old posistion
pos2 VAR Word
pos2_old VAR Word
mag VAR Word 'Magnitude of ange
diff VAR Word 'Differnce from new and old new- old
center1 VAR Word 'Calculated straight up RC time factor
center2 VAR Word
counter VAR Nib
vel1 VAR Word
vel2 VAR Word
total VAR Word
'Calibration
HIGH 10
FOR counter = 0 TO 14
HIGH 3
HIGH 2
RCTIME 3,1, vel1
RCTIME 2,1, vel2
center1 = vel1 + center1
center2 = vel2 + center2
PAUSE 50
NEXT
LOW 10
center1 = center1 /15
center2 = center2 /15
pos1 = center1 'Center
pos2 = center2
main:
pos1_old = pos1 'Set last posistion taken to
pos2_old = pos2
HIGH 3 'set pin 3 high in prep to run rctime
HIGH 2
RCTIME 3,1, pos1
RCTIME 2,1, pos2
IF ( pos1 < center1 ) THEN 'Need to go to Fwd
mag = ABS(center2-pos2)
diff = ABS(pos2_old-pos2)
total = ((mag)+(diff))*4 MAX 150 MIN 0
GOTO Fwd
ELSEIF ( pos2 < center2 ) THEN 'Need to go to reverse
mag = ABS(center1-pos1)
diff = ABS(pos1_old-pos1)
GOTO Rwd
ELSE
GOTO main
ENDIF
GOTO main
RWD:
vel1 = total + 750
vel2 = 750 - total
GOTO ServoC
FWD:
vel1 = 750 - total
vel2 = total + 750
GOTO ServoC
ServoC:
PULSOUT 13,vel1
PULSOUT 12,vel2
GOTO main
FWD:
PULSOUT 13, 750 - total
PULSOUT 12, total + 750
RETURN
(I think that will work)
- Stephen
Now that you mention moving the pulsout, I may just get rid of the subroutines and throw all the commands in the respective IF statements.
which can add to a "jerky" motion. Using COUNT would allow you to at least set a specific time window that will keep your loop iterations more predictable. To do this you need to feed your sensor into a 555 or
74HC14 Schmitt trigger type of oscillator. The output of the oscillator will be a continuous stream of pulses that can be measured with the COUNT command.
Beau Schwabe
IC Layout Engineer
