Controlling External PWM Generator with A Stamp with Variable Speed/Duty Cycle — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2006-06-19 14:32 in BASIC Stamp
Anybody got any suggestions on a design that uses an external PWM circuit, where the frequency and duty cycle can be controlled by a Stamp BS2P40? I am looking to develop a chopper circuit for a bi-polar stepper motor for current limiting control. Since I am putting in the additional circuitry, I thought it would be cool to test the torque, speed, and heat of the driver/motor with variable PWM as a current limiting feature. I would want to be able to adjust the frequency of the PWM up or down from say hundreds of cycles to 25k approximately, adjust the duty cycle from 0 to 100% on the fly.
Right now it looks like a typical PWM oscilator with a digital pot in the RC network for Frequency, plus a digital pot for duty cycle (digitally setting the reference level to comparator) would be the stuff to sort out. \
The Stamp is too busy to generate the PWM, adding another Stamp is too costly, but maybe an SX would be feasable.
    edited 2006-06-19 09:07
    Originator -
    Take a look at the Parallax PWM Pal which fits right underneath the Stamp and thus takes up no real estate. Here is a link to it:
    http://www.parallax.com/detail.asp?product_id=28020
    Four separate channels of PWM at the cost of one Stamp pin. Can't beat that.
    Bruce Bates
    <!--StartFragment -->
    Bruce Bates said...(trimmed)
    Bruce's suggestion is valid but I just wanted to clarify that when 4 channels are enabled you will effectively lose the use of 5 BASIC Stamp I/O pins since they share with the socket.· One clever customer made a strange breakout board which has the PWMPAL side-by-side with the PWM PAL and only connected to the P0 line, freeing up all the other lines which could be shared (up to 8).
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
