anyone seen "weaker" linear actuators?
Hello, I'm looking for a "weaker" linear actuator (one that can pull or push less than 5lbs) with around 6" of travel? All of the ones I've seen online push at a minimum of 28lbs!
This one isn't a whole lot better, but at the low end it's 100 Newtons, or 22.5 lbs of force:
http://www.mpja.com/productview.asp?product=16052+MS
Bruce Bates
<!--StartFragment -->
Bruce - now that's pretty darn close to what I was looking for! thanks!
Key "linear actuator" into this search engine, and you should come up with a number of products from Herbach and Rademan:
http://www.herbach.com/
Bruce Bates
