Top File.spin — Parallax Forums
Top File.spin
NewzedNewzed Posts: 2,503
edited 2006-06-17 19:10 in Propeller 1
Subject file is Example 01 of Dave Scanlan's posting.· I can not get it to run.
I connected an LED to Pin 16/Gnd and to Pin17/Gnd.· When I powered up, LED 16 turned on, LED 17 was off.· I brought up Top File.spin on the screen, clicked on Run/Compile Current/Load RAM and Run.· LED 16 turned off very briefly and LED 17 flashed one time.· It made no difference whether Pin 4 was grunded or ungrounded.· I reversed the LED pins in Top File.spin -· the result was the same.
I restored the LEDs to their original configuration, clicked on Run/Compile Current/Load Ram and Run.· Same result.
Clicked on Run/Compile Top/Load Ram and Run. Same result.
Clicked on Run/Compile Top/Load EEPROM and Run.· Got an error message "Programming Error on Com1".
Clicked on Run/Compile Current/Load EEPROM and Run.· Got an error message "EEPROM verify error on Com1".
Can someone please help?
Sid
  • NewzedNewzed Posts: 2,503
    edited 2006-06-17 15:15
    EEPROM error corrected.· Had no ground.· Nothing else works yet.
    Sid
    Never mind -· I finally got it working.
    Sid
