Passing Port Pins as Arguments
I was experimenting with the SEROUT command and found that the first argument, the port pin, must be the port pin directly:
SEROUT ra.0,T2400,"A"
I have an application for using multiple serial devices from the same SX machine so I would want to encapsulate SEROUT in such a manner that the port pin would be an argument to a wrapper:
'one serial device
MySEROUTFunction rb.0 'send a byte from rb.0
'another serial device
MySEROUTFunction rc.5 'send a byte from rc.5
MySEROUTFunction would be something like:
MySEROUTFunction:
temp1=__PARAM1
SEROUT temp1,T2400,"A"
Upon review of the SEROUT assembly, I though I could specify the port however I could not determine how to specify the pin.
Any ideas?
Joe
'one serial device
MySEROUTFunction:
temp1=__PARAM1
Any ideas?
Joe
This was just asked a couple days ago.
Pins cannot be passed as parameters because the assembly commands that set and clear a single bit are hard coded into the instruction.
You could possibly do it if you made your own SEROUT command where you could specify the port and bit mask.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
