My Peopeller won't SPIN
Finished assembling my board, checked all DC voltages, plugged in the Propeller and the other two chips.· Tried both USB2SER and my serial cable· but my PC can not find the Propeller,· The board is laid out exactly like the PropStick -· I think.· The only difference is· I am using a 2N2222A instead of a 2N3904.· I have attched the Express layout of the board.· Just remember you are looking at the botton of the board·- Pin 1 of all chips has a square pad.
I hope someone can help.· I would really like to get my Propeller SPINning.
Sid
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
Sid
Sid Weaver
Chip Gracey
DB9.2 to 3232.7
DB9.3 to 3232.8
DB9.4 to 3232.13
3232.9 to Prop.A31
3232.10 to Prop.A30 - pulled high
Could using the 2N2222A instead of the 2N3904 cause a problem?
I'll try anything you suggest.· Remember I'm using a built up PC board.
Sid
Sid Weaver
Chip Gracey
Chip Gracey
This could be a little confusing. If he's using a true 2N2222 (in the metal can), you're right: the pinout is reversed. But if what he's actually using is a PN2222 (TO-92), it has the same pinout as the 2N3904 (i.e. EBC, flat side up, pins down).
TO-18, I think.· Couldn't find a data sheet for a TO-92.
Sid
Sid Weaver
Sid
Sid Weaver
