Is this a clean interface for the MAX7219 LED Driver?
I just want to make sure I have the Wiring connected correctly.· SegA-SegF, SegDP·run to each display.
Each Display has it's independent "Control", through D0-D7.
Please let me know if this is correct.
Thanks.
Shaun
Thanks.
Shaun
Chris Savage
Parallax Tech Support
csavage@parallax.com
I agree with Chris. Most people post massive BMP files that are too big and un-compressed. You went the opposite way and posted a very small JPEG with a lot of compression. Re-post with a JPEG that's about 1000 pixels wide, or until it's big enough to clearly read the schematic.
Thanks, PeterM
·- Rick
Here is the PDF of it in a circuit.· It it takes up too much bandwidth, I will remove it from the server (43k)
Sorry about not replying...I've been pretty busy...
