Switching Supply
Hello
···· I have a battery pack that has 120vdc comming out of it and want ot drop it down to about 30vdc so I can then use a linear regulator to get voltage needed to run my stamp circuit. Does anyone know of a way to drop it down say like a switching power supply circuit? I need atleast 10 amps.
Post Edited (bennettdan) : 6/13/2006 9:21:54 PM GMT
This will be a pretty serious design project if you need a reliable unit. I've used some packaged units from Melcher which will certainly do the job. They are efficient switching units and are bulletproof.
If you decide to build your own, it goes without saying that your battery bank can inflict damage and injury if it gets away from you. The crudest designs will have short pulses at 120 VDC with an average of 30 VDC. Without proper filtering and regulation, your downstream equipment will be exposed to peaks many times over its rating.
Is there any other way to feed your system?
I was involved with electric vehicles back in the 80's and had a great time experimenting. Did some early work on a 400 Amp chopper for main motor control. It was an early use of MOSFETS where I put 40 in parallel. A real monster but really demonstrated that the MOSFET was easy to control and would load-share reasonably well.
PJ's suggestion will work as well as the Melcher I suggested and will allow you to keep going without getting bogged down in a design project!
Cheers
If you decide to build your own, why not use a spare IGBT even though it will be over-kill.....you'll always have a spare drive transistor with you!
To drive the Gate of the IGBT, you could probably use something like the PWMPAL from Parallax and use a Stamp to monitor the output voltage and adjust the PWM level to keep the average voltage within range. Would still need lots of filtering, but shouldn't be too hard.
Any pics of your truck?
Cheers,
Tom
www.siskconsult.com
