Assembly Documentation & Half-Duplex Serial Receiver
Timothy D. Swieter
I was curious when more assembly documentation for the Propeller would be released?
I am currently trying to do a DMX receiver. I am realizing that the speed of DMX (250K BAUD - 4us bit, 320 Clock Cycles) means that I need to be doing this in assembly. I started by reviewing the FullDuplexSerial Object (thinking maybe I could use just the receive portion of the assembly routine) and looking at the Assembly Elements PDF. It has been a while since I did something in assembly, but I think I can get through it with a little more documentation (and maybe more help from this forum).
If someone has already developed an assembly half-duplex driver, I loved to see that too! No sense reinventing the wheel.
Timothy D. Swieter
www.tdswieter.com
One little spark is all it takes for an idea to explode
Timothy D. Swieter
www.tdswieter.com
PRI serin : b | t waitpeq(0, |< rx, 0) t := cnt + baud >> 1 repeat 8 waitcnt(t += baud) b := ina[noparse][[/noparse]rx] << 7 | b >> 1 waitcnt(t + baud)The variable baud, as defined by monitor (and similarly my program), is 320 for DMX. I have observed with my program, that 320 clock cycles had elapsed before I got to waitcnt(t += baud) thus my program would hang for a minute until the counter came back around. Beasue of this, I was thinking I needed to try and have a routine in assembly. I can experiment more with it, but I don't have any more instructions then you do between the intial logging of cnt and the waitcnt.
Timothy D. Swieter
tdswieter.com
Sorry about that, I misread your post. You wrote 250K, but I was reading too quickly, and saw 2400. So, I thought the spin version would work fine, but as you pointed out, the spin waitcnt command doesn't work for times that small.
Regards, Andy
- mov txcode, #transmit
- mov txcode #receive
- jmpret rxcode, txcode
I think it might be possible to rearrange the placement of these commands so that only jumps from the to transmit to the receive (or the other direction) when the buffer is empty (or with 17/19 software flow control, or hardware flow control).
It would be nice to simply add a mode bit to the start method for half duplex. I don't see exactly how to do it on my first examination of the code.· It seems like it should be possible though.
I also thought it would be nice if FullDuplexSerial would have a mode bit for half/full operation. I will look more into the assembly routine tomorrow and see if I can understand it more.
Andy, do you know when more information on Propeller assembly language will be available? I appreciate your help.
Timothy D. Swieter
tdswieter.com
In the meantime, a document I find really helpful is called Core Docs.pdf, which should be in the Propeller Tool folder at the same level as Propeller.exe. It's got a table with all the assembly commands on page 5 and a lot of useful assembly information throughout.
You'll see on page 5 that the waitpeq instruction is
WAITPEQ D, S
It also says that the destination (D) is equal to INA ANDed with the source (INA & S). What that really means is that INA is ANDed with C, and the program waits for that result to be equal to D.
I just found out from our software engineer that when you use this command, make sure to clear the C flag; otherwise, it'll checking port-b, which doesn't exist on the 32 I/O version of the chip.
Post Edited (Andy Lindsay (Parallax)) : 6/10/2006 3:33:46 AM GMT
My weekend ended up being too busy to start investigating the assembly half-duplex idea. Maybe later this week.
Timothy D. Swieter
tdswieter.com
You mentioned to clear the C flag just before using waitpeq. What is the best way to do this? Is it simply done by add #0, #0 wc or is there a better way?
Timothy D. Swieter
tdswieter.com
rdlong bitticks,t1 ' cycles between MIDI bits mov halfticks,bitticks shr halfticks,#1 mov noncmd,#receive mov newnote,#receive ' ' Receive ' receive test rxmask,ina wc ' Wait for start bit if_c jmp #receive mov rxbits,#9 ' Ready to receive byte mov rxcnt,halfticks add rxcnt,cnt :bit add rxcnt,bitticks ' Ready next bit period :wait mov t1,rxcnt ' Check if bit receive period done sub t1,cnt wz if_nz jmp #:wait test rxmask,ina wc ' Receive bit on rx pin rcr rxdata,#1 djnz rxbits,#:bit shr rxdata,#32-9 ' Justify and trim received byte and rxdata,#$FF '' '' A byte has been received ''I have two questions about this code. First, if I take the two lines
mov rxcnt,halfticks add rxcnt,cntand instead make them
mov rxcnt,cnt add rxcnt,halfticksthings stop working. Why? I always thought a+b = b+a..... The second question is that the value of halfticks has to be EXACTLY one half of bitticks for the code to work. Again, why? The way I understand it, that is just positioning the TEST instruction to the middle of the bit time, and it should not be that sensitive.
Sorry, my mistake. It doesn't matter what the C bit stores in the current 32 I/O pin chip. Apparently, that feature is on the drawing board for a 64 I/O pin chip.
Yes, if you have to clear C, use a command that won't carry along with WC.
Andy
It looks like there is a bug in the modified program that has it really close to the edge as far as timing is concerned. In both of your observations, tiny changes in timing are pushing it over the edge. (A + B and B + A are not equal in this case because cnt will store a different value.) If you try those small changes in the original code, it should still work, even at much higher baud rates.
I've also been wanting to try my hand at adding a half duplex option to FullDuplex.spin. Maybe when I get further into it, I'll see the problem, but right now, I don't.
Andy
:wait jmpret rxcode,txcode 'run a chuck of transmit code, then return mov t1,rxcnt 'check if bit receive period done sub t1,cnt cmps t1,#0 wc if_nc jmp #:waitwith
:wait mov t1,rxcnt ' Check if bit receive period done sub t1,cnt wz if_nz jmp #:waitwhich is not the same thing at all. My code had to hit zero exactly - it's a wonder I ever got it to work!
