IC Pins too wide
Just a quickie for all you pro's.· The width of all new·IC pins are wider than the spacing when a pc board is made.· Normally this just requires a little friendly persuasion and patience to fit them in.· However my patience is running out this time as I have to mount 900 IC's.· Is there a tool or something that compresses the pins on new IC's and makes easy the alignment and insertion on a PC board?
Thanks in advance
Thanks in advance
·· Which ICs do you refer to?· I have not seen any issue with the new SX chips, but if that's what you refer to please let us know which one it is that's·may be·having the problem so we can look into it further.· Thanks.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I cannot understand why there isn.t some type tool that I could grab the IC with and by squeezing it get my .3" so it would just be aligned perfectly.
Eric
I could imagine modifying a pair of needlenose pliers to have a right-angle on the end of both surfaces, so that both sides of the 300 mil DIP could be pressed inward the same amount. Add some type of depth stop as well.·Just a thought, though there must be some off-the-shelf tool that would do the trick.
I'm using the IC Pin Straightener avalable from Digikey, part-# A998-N. There are also various insertion tools available at Digikey but unfortunately, I could not find one that fits the SX 28 so far.
Greetings from Germany,
G
For myself, needlenose are a disaster as I tend to over do some.
With 900, you might be able to use the cutting board; but the pin straightener is best.
I don't think it is a new problem [noparse][[/noparse]circa 1970s, I had the same].
That is why Guenther has an IC Pin Straightener [noparse][[/noparse]they are a bit expensive].
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
c'mon - before manually adjusting the pins of 900 chips using a cutting board, the pin straightener adds costs of about 0.1 cent per chip, so it's peanuts.
G
The reason the pins are splayed is because that way the automated machinery can grab them with just friction.
Secondly, when they are installed into the PCB, they will try to spring back (provided the pins have not yielded), and prevent the ICs from falling out of the board while it is being handled as others are inserted. It would be a real mess without this "board hugging" feature as our automated dip shooter fires as fast as one chip per couple of seconds!
As far as I can recall, they have been manufactured that way since the 1970's.
There are standard manual IC grabbers (DIP) avaialable to assist the manual assembly process. As a DIP is interted into it, the pins are squeezed to the correct 0.3 inch width. Probably $10 to $20.
Cheers,
Peter (pjv)
