FlexiForce Pressure/Time Measurement
I would like to build 1 or·more pressure sensitive mats for performance measurement using the BS2
for a 100lb person.
Here are the scenarios:
1) Person stands on floor next to mat, jumps onto mat then quickly jumps off. Measure how long they were on the mat before jumping off.
2) Person stands still on mat, jumps straight up and down on the mat once. Measure how long they were off the mat.
3) Person stands still on mat, then jumps off mat on queue. Measure reaction time.
I have the flexiforce sensor and the demo is about·at my skill level since it provides a pictorial and the BOE though I have the homework board).
Is this the appropriate sensor to use?
Do I need 3 separate setups?
for a 100lb person.
I would suggest that you go through the What is a Microcontroller book here:
www.parallax.com/dl/docs/books/edu/wamv2_2.pdf
and try and create a similar setup using a pushbutton switch, and once you have built a program/interface that works with a push button, you can then consider scaling it to work with a person jumping on a mat.
These sensors do not survive shear stress or abuse at all well. If you do this, then make arrangements with a rubber or gel mat under a platform or something like that to spread out the force and to direct it straight down on the sensor. If you just need a yes or no signal, one sensor would be fine, or as Tristan suggested, something just using a switch.
Tracy Allen
www.emesystems.com
Here is a link to an inexpensive mat that approximates the interface. I'm wondering how I can connect it to the BS2 as a switch:· http://www.maplin.co.uk/Module.aspx?ModuleNo=3091&TabID=1&source=1&
Alternatively would the BS2 be able to·interface with·the B201 FlexiForce model as easily as the low-weight version as seen in this link? http://www.tekscan.com/pdfs/Brochure_Flexiforce.pdf
Cdub
