Advice needed for recovering data generated via a F/F being used for pulse outp
Buck Rogers
Hello!
Using some what modified versions of Pulsout.bs1 (examples attached), I have successfully used these to clock an SN7472 flip flop. I now need to recover the data created from the Q output of the flip flop and then present it as an output via the SEROUT instruction.
A brief description of what the actual circuit looks like and what is happening is prsented at www.gregg.levine.name in the category One-Wire circuits.· I need to send the resulting stream to a PalmVx running a program called PalmOrb available from·http://palmorb.sf.net·.
I have already worked out the details concerning the Palm and the connections to the ·HotSynch connector and actually own a Serial HotSynch cable.
Buck Rogers
Buck Rogers
' {$STAMP BS1} ' {$PBASIC 1.0} SYMBOL A = BIT0 SYMBOL B = BIT1 SYMBOL C = BIT2 SYMBOL D = BIT3 SYMBOL X = B2 INPUT 0 'P0 = F/F 1 INPUT 1 'P1 = F/F 2 INPUT 2 'P2 = F/F 3 INPUT 3 'P3 = F/F 4 OUTPUT 7 The_Top: X = 0 X = A * 1 X = B * 2 + X X = C * 4 + X X = D * 8 + X SEROUT 7, T2400, (X, " ") PAUSE 1000 GOTO The_Top
