COMPARE Function on BS2Px
Good morning!
I am wondering how the COMPARE function compares vaoltages. Does it have (3) states? ( A higher than B, B higher than A and A=B) More importantly (because the Stamp is a digital device), can the Stamp only compare voltages that are 0 or 5 volts? Or can I, say, have the voltages be 2.7V and 4.2V and compare them (without the Stamp going wonky because of being in a digitally indeterminant state).
I have a circuit that looks at a sensor reading (voltage) and compares it to a set point (manually controlled; the other voltage). The comparator circuit is fairly robust, but I am interested in having the mu-C be the comparator so that we can change things as needed.
Thanks for any help!
Smokey
Freeing smoke from wire and IC captivity since 1972
Smokey
·· The comparator is analog and can handle analog voltages within the input range of the I/O pins.· The best source of technical data on this function would be the SX datasheet located at the following link.· Take care.
http://www.parallax.com/dl/docs/prod/datast/SX48BD-Data-v1.1.pdf
Chris Savage
Parallax Tech Support
csavage@parallax.com
Like any comparator, it has two states at the output, either p1>p2 or p1<p2, and if p1=p2 or close to it, you will see noise in the output and in the result variable. Just as with any comparator, you can add a bit of positive feedback to create hysteresis.
Tracy Allen
www.emesystems.com
Until the next time I free smoke from their bonds... I appreciate the help.
