Proposed robot — Parallax Forums
Proposed robot
StampNut2StampNut2 Posts: 224
edited 2006-06-10 23:37 in BASIC Stamp
Hello guys
I need help please if you can, I am new to pbasic [noparse][[/noparse]but learning] through parallax manuals it will take me time as I am SLOW LEARNER.
I have the Professional dev board/ 2 x HB 25 motor controllers and also a Bluebell design co-processor board connected to th dev board. Connected to the HB 25 are two como drill piledrive motors. The co-processor
board has two bump and one irpd sensor all of this works great and does what it is supposed to do. I am using the subsume_libby96.bsp code for this to function.
However I wish to add a ping ultrasonic sensor/pir sensor module/parallel lcd to read the ping distance and have two servos for pan/tilt UNFORTUNATLY I do not know where to place the code in the libby program or the code used to make these extra functions work.
I find it a lot easier if I have code already made so a project can work then if I need to alter this I can do a bit at a time and see what the results are, I find it easier to learn this way although you may not agree with this statement.
I am 53 and not a young person entering this field of robotics programming but find it very facinating. I have had over 30yrs in digital/analogue circuit building robots but they have all been hard wired and no software to run them.
Will post some pics later of my workshop and project. The co-processor has the facility for 8 servos and 4 A/D input lines.
+ the extra 28 I/O from the stamp.
Never give up when things go wrong.
Post Edited (StampNut2) : 6/12/2006 4:16:53 AM GMT
  • mukarrammukarram Posts: 16
    edited 2006-06-10 22:56
    <b>Mukarram[sup]Emc[sub]2[/sub][/sup]Ahmad[/b]
    </b>
  • StampNut2StampNut2 Posts: 224
    Thanks mukarram, At present it will avoid obsticles using irpd sensors and bump sensors. I wish to add the above sensors to this project and would like the code to go with it and where to insert it. I will try and get the libby code here so you can have a look.
    '{$STAMP BS2p}
    ' Subsume_Libby96.BSP - This shows the Subsumption engine in the Stamp 2p40.
    ' It uses the ramping servo controllers and sensors from the Co-Processor
    [noparse][[/noparse] I/O Definitions ]
    To_Co_Proc CON 10 ' pin for data to BBDI Co-Processor
    Frm_Co_Proc CON 9 ' pin for data from BBDI Co-Processor
    Timer_Exp VAR IN11 ' Timer Expired I/O pin from BBDI Co-Processor
    BAUD CON 240 ' 2400 BAUD => BS2 = 396, BS2p = 1021 = CoProc V1.0
    ' 9600 BAUD => BS2 = 84, BS2p = 240
    ' CoProc V1.1 pin 21 pulled up = 2400 Baud
    ' CoProc V1.1 pin 21 grounded = 9600 Baud
    LF CON 10 ' Line Feed
    [noparse][[/noparse] Constants ]
    bot_control CON $D5 ' this byte controls the Subsumption Architecture.
    ' it is programmable in Co-Processor
    ' bot_control is also defined below as its separate named bits for clarity here
    ' D = Ball Bearing = 1; Show Vision = 1; level 5 = 0; do_bumpers = 1;
    ' 5 = level 3 = 0; do_vision = 1; level 1 = 0; do_bot = 1
    Ball_Bearing CON 1 ' Ball Bearing determines the relative directions
    ' vs servo pulse width. Libby has ball bearing
    ' servos so it is set to 1. This program will
    ' not show Ball Bearing usage.
    Show_Vision CON 1 ' IF enabled shows the vision output on chan 6 and 7
    level_5 CON 0 ' Level 5 is like Level 1 except highest priority
    do_bumpers CON 1 ' bumpers are at level 4
    level_3 CON 0 ' Level 3 is like Level 1 except higher priority
    do_vision CON 1 ' enable vision from the IR Proximity Detector
    level_1 CON 0 ' you write the direction and duration for level 1
    ' and it gets integrated into the Subsumption
    ' calculations.
    ' The lowest level is randomly wandering around.
    ' it is always enabled
    do_bot CON 1 ' enables the subsumption engine.
    'Values shown are initialization values
    LEFT_STOP CON 127 'Left Stop - reprogrammable in Co-Processor
    RIGHT_STOP CON 127 'Right Stop - reprogrammable in Co-Processor
    LEFT_MIN CON 0 'Left Min - reprogrammable in Co-Processor
    RIGHT_MIN CON 0 'Right Min - reprogrammable in Co-Processor
    LEFT_MAX CON 255 'Left Max - reprogrammable in Co-Processor
    RIGHT_MAX CON 255 'Right Max - reprogrammable in Co-Processor
    ' DIRECTION VALUES WRITTEN INTO THE DRIVE REGISTER BY THE VARIOUS BEHAVIORS
    'Direction, bit3, bit2, bit1, bit0
    'xxyy
    'xx = 00 -> left motor stopped
    'xx = 01 -> left motor forward
    'xx = 10 -> left motor backward
    'xx = 11 -> left motor forward
    'yy = right motor
    'normal list follows
    fd CON %0101 'forward
    rv CON %1010 'reverse
    st CON %0000 'stop
    tr CON %0100 'turn right
    tl CON %0001 'turn left
    rr CON %0110 'rotate right
    rl CON %1001 'rotate left
    bl CON %1000 'backup turning left
    [noparse][[/noparse] Variables ]
    SerDIn VAR Byte 'gets serial data back from Co-Proc
    ServVal_0 VAR Byte 'to load servo 0 delays
    ServVal_0_Old VAR Byte 'remember old servo 0 delays
    ServVal_1 VAR Byte 'to load servo 1 delays
    ServVal_1_Old VAR Byte 'remember old servo 1 delays
    ramp_0 VAR Byte 'servo 0 ramp rate
    ramp_1 VAR Byte 'servo 1 ramp rate
    Drive VAR Byte 'each behavior subroutine writes direction here
    wDir VAR Byte 'Wander Direction
    wDur VAR Byte 'Wander Duration
    IRPDDir VAR Byte 'IRPD Direction
    IRPDDur VAR Byte 'IRPD Duration
    bDir VAR Byte 'Bump Direction
    bDur VAR Byte 'Bump Duration
    L1_Dir VAR Byte 'Level 1 Direction
    L1_Dur VAR Byte 'Level 1 Duration
    L3_Dir VAR Byte 'Level 3 Direction
    L3_Dur VAR Byte 'Level 3 Duration
    L5_Dir VAR Byte 'Level 5 Direction
    L5_Dur VAR Byte 'Level 5 Duration
    i VAR Byte 'used by IRPD
    seed VAR Word 'random number seed
    ir_left VAR SerDIn.BIT5 '1 = IR sensed something on left side
    ir_right VAR SerDIn.BIT6 '1 = IR sensed something on right side
    bumper_Left VAR Bit '1 = IR sensed something on left side
    bumper_Right VAR Bit '1 = IR sensed something on right side
    first_bump VAR Bit 'tells first impact for immediate stop
    bstate VAR Nib 'holds state of bumper FSM
    [noparse][[/noparse] Initialization Code ]
    ServVal_0 = LEFT_STOP + 1 ' need a value different from what
    ServVal_0_Old = LEFT_STOP + 2 ' is to be sent
    ServVal_1 = RIGHT_STOP + 1
    ServVal_1_Old = RIGHT_STOP + 2
    ramp_0 = 24 '6 counts/20ms
    ramp_1 = 24 '6 counts/20ms
    first_bump = 0
    bumper_Left = 0
    bumper_Right = 0
    AUXIO '2p40 processor only!
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]116]
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]116] 'Reset Co-Processor
    'Reset turns servos off
    ' and turns ramping off
    ' We would normally initialize for robot operation. That would start the IRPD
    ' (IR Proximity Detect). Here we don't want the Subsumption Engine to start.
    ' We just want to turn on the IRPD so we can look at what is happening.
    ' Notice that the IRPD LEDs can still light IF you set the bot_control.
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]214,23] 'write IR Freq Register
    'default = 23; max sensitivity = 27; min = 20
    'Writing a nonzero value enables the IRPD
    'period = 15.6 + 0.4*counts (us) (23 = 24.8uS)
    'Change the 23 to other values and see the effect
    ' on sensitivity.
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse](218)] 'command to write bot_control
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]$40] 'run the IRPD display LEDs but not the robot.
    'without this command the display LEDs (ch 6 and 7)
    ' won't light.
    ' D = Ball Bearing = 0; Show Vision = 1; level 5 = 0; do_bumpers = 0;
    ' 5 = level 3 = 0; do_vision = 0; level 1 = 0; do_bot = 0
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]144,ramp_0] 'write ramp rate to servo 0
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]145,ramp_1] 'write ramp rate to servo 1
    'Ramp rate of x will incr or decr
    ' pulsewidth by x/4 per 20 ms
    ' up to a max of x = 31
    'write ramp command = 144 + ch#
    [noparse][[/noparse] Main Code ]
    Main: 'subsumption architecture
    GOSUB Rd_Sensors ' check bumpers and vision values
    ' takes 9.6 ms (mostly because
    ' 2 bytes @ 2400 Baud = 8.33ms)
    ' (9600 Baud will reduce by over 6ms)
    IF do_bot = 0 THEN no_subsum: ' subsumption engine enabled?
    ' subsumption takes 5.8 ms to execute
    'Below are the behaviors (in subroutines)
    GOSUB wander 'do the random wander about subroutine (Level0)
    ' wander is lowest priority
    GOSUB Level1 'do user subroutine
    GOSUB IRPD 'do the IRPD subroutine (Level2)
    GOSUB Level3 'do user subroutine (not shown)
    GOSUB bumpck 'do the bumper subroutine (Level4)
    GOSUB Level5 'do user subroutine (not shown)
    ' Level5 is highest priority
    GOSUB action 'figure out servo values from results of
    ' previous subroutines
    no_subsum:
    PAUSE 5 'NEEDED TO KEEP LOOP AT ROUGHLY 20 MS FOR DURATION COUNTERS
    ' DECREMENT IN THE RIGHT AMOUNT OF TIME
    ' 9.6 ms + 5.8 ms = 15.4 ms -> need 5 more
    ' for 20.4 ms period
    GOTO Main 'keep looping doing it
    [noparse][[/noparse] Subroutines ]
    Rd_Sensors: ' reading the sensors takes 9.6 ms,
    ' of that, 8.3 ms is the serial transfer
    'structure of bot_status byte from the CoProcessor
    'bstate1 VAR BIT 'Bumper Finite State Machine = LSB
    'bstate2;
    'BumperFlg_Leftbmp VAR BIT 'bumper hit
    'BumperFlg_Rightbmp;
    'first_bump VAR BIT 'bumper just hit - to stop NOW!
    ' N/A if robot mode isn't running
    'see_on_left VAR BIT 'vision sees something on left
    'see_on_right VAR BIT 'vision sees something on right
    'bit7 VAR BIT 'NOT USED = MSB
    ' read_CoProc 'read the value from the CoProcessor
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]118] 'Send the byte command to read robot status
    SERIN Frm_Co_Proc, BAUD, [noparse][[/noparse]SerDIn] 'Data comes back into SerDIn
    'since ir_right is defined as SerDIn.BIT6 and
    ' ir_left is defined as SerDIn.BIT5,
    ' they are set by the definitions
    IF (SerDIn & $08)=0 THEN chk_bmp_L
    bumper_Right = 1 '1 = hit something on right side - bit is sticky
    ' it is reset in bumper FSM
    chk_bmp_L:
    IF (SerDIn & $04) = 0 THEN done_sense
    bumper_Left = 1 '1 = hit something on left side bit is sticky
    done_sense:
    RETURN 'completed
    wander: ' The lowest level is randomly wandering around.
    IF wDur > 0 THEN wDone0
    RANDOM seed 'random direction
    LOOKUP (seed & %111),[noparse][[/noparse]fd,tl,fd,fd,fd,tr,fd,fd],wDir
    RANDOM seed 'random duration
    wDur = (seed & %1111111) 'mask for 128 choices of duration
    IF wDir = fd THEN add20
    wDur = wDur & %111111 'mask turns down to 64 choices of duration
    add20:
    wDur = wDur + 20 'add 400ms for a minimum duration
    wDone0:
    wDur = wDur - 1 'decrement wander counter
    drive = wDir 'get direction
    RETURN 'completed
    Level1: 'do user subroutine
    ' calculations.
    IF level_1 = 0 THEN Done1 ' not enabled
    IF L1_Dur = 0 THEN Done1 ' not active now - timed out
    L1_Dur = L1_Dur - 1 ' decrement duration counter
    drive = L1_Dir ' get direction
    Done1:
    RETURN ' completed
    IRPD: 'do IRPD Vision subroutine
    IF do_vision = 0 THEN IRPDdone ' not enabled
    'decide on movement direction always
    i = ir_left * 2 + ir_right '1=right, 2=left, 3=both
    BRANCH i,[noparse][[/noparse]IRPDDec,IRPDleft,IRPDright,IRPDfront] 'if IR left -> go right
    IRPDfront:
    IRPDDir = rl 'rotate left away
    ' internal CoProcessor code rotates randomly either direction
    IRPDDur = 16 'Duration + 1
    drive = IRPDDir
    RETURN
    IRPDleft:
    IRPDDir = tl
    ' IRPDDur = 10 'same # as IRPDright - so share
    GOTO IRPDsdur
    IRPDright:
    IRPDDir = tr 'turn right
    IRPDsdur:
    IRPDDur = 10 'Duration + 1
    ' goto IRPDDec 'falls through
    IRPDDec: 'decrement current one
    IF IRPDDur = 0 THEN IRPDdone 'no IRPD move in progress
    IRPDDur = IRPDDur - 1
    IRPDDrv:
    drive = IRPDDir
    IRPDdone:
    RETURN
    Level3: 'do user subroutine
    IF level_3 = 0 THEN Done3 ' not enabled
    IF L3_Dur = 0 THEN Done3 ' not active now - timed out
    L3_Dur = L3_Dur - 1 ' decrement duration counter
    drive = L3_Dir ' get direction
    Done3:
    RETURN ' completed
    bumpck: 'do bumper subroutine (= Level4)
    'Bumper reaction Finite State Machine (FSM)
    ' State 0 = idle, just checking IF bumper is hit
    ' State 1 = currently backing up from hit
    ' State 2 = rotating away
    IF do_bumpers = 0 THEN bDone4 ' not enabled
    IF SerDIn.BIT2 = 1 THEN bmpnow 'Being bumped on left now! Restart state machine
    IF SerDIn.BIT3 = 1 THEN bmpnow 'Being bumped on right now! Restart state machine
    IF bDur > 0 THEN bmpact 'not done current state yet, continue bump
    ' action set by going into current state
    'current state finished, set next state
    BRANCH bstate,[noparse][[/noparse]bDone4,end_st1] 'jump to states 0-1, state 2 immed. follows
    IF i < 3 THEN breset 'if both IR sensors aren't lit, done spinning
    keepspin:
    bDur = 20 'something is still in front, need to keep spinning
    GOTO bdrive
    breset: 'end state 2, now reset
    bstate = 0 'state machine to idle
    RETURN
    end_st1: 'end state 1, now
    IF bumper_Left = 0 THEN rtbmp
    bDir = rr 'rotate right away from left bump
    GOTO bmpdur
    rtbmp:
    bDir = rl 'rotate left away from right bump
    'internal CoProcessor code is random direction if both bumpers hit
    bmpdur:
    bDur = 25 'internal CoProcessor code is random from 0.2 to 0.5 seconds
    first_bump = 0 'reset sticky bits
    bumper_Left = 0
    bumper_Right = 0
    bstate = 2 'next state
    GOTO bdrive
    bmpnow: 'being bumped now!
    IF first_bump = 1 THEN still_bmp 'still being bumped?
    first_bump = 1 'capture first bump only
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]152,LEFT_STOP] 'write position to servo 0 - immediate stop!
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]153,RIGHT_STOP] 'write position to servo 1 - immediate stop!
    ' trick - will over-ride ramping to stop but
    ' start ramping to the new value from there.
    still_bmp:
    bDir = rv 'set backup while bumped and
    bDur = 18 'for a while (+1) after not being bumped
    ' internal CoProcessor code duration is shorter (10) if
    ' only one bumper side is hit
    bstate = 1 'start state machine
    bmpact: 'bump mode active
    bDur = bDur - 1 'decrement bump timer
    bdrive:
    drive = bDir 'set drive direction to bump
    bDone4: 'no bump and state machine not running - done level 4
    RETURN ' completed
    Level5: 'do user subroutine
    IF level_5 = 0 THEN Done5 ' not enabled
    IF L5_Dur = 0 THEN Done1 ' not active now - timed out
    L5_Dur = L5_Dur - 1 ' decrement duration counter
    drive = L5_Dir ' get direction
    Done5:
    RETURN ' completed
    action: 'moves servo motors
    'uses ramping servo controller for simplicity
    'servo 0 = Left, Servo 1 = Right
    ' Ball Bearing assumed to be 1 (for Libby)
    ' Ball Bearing being 0 reverses MINs and MAXes
    ' see Subsume_BoeBot1.BS2
    IF drive.BIT2 = 1 THEN lftfwd 'jump if want to move left motor forward
    IF drive.BIT3 = 1 THEN lftbak 'jump if want to move left motor backward
    GOTO lft_pulse
    lftbak:
    ServVal_0 = LEFT_MAX 'MIN is backward when BB = 0
    GOTO lft_pulse
    lftfwd:
    ServVal_0 = LEFT_MIN 'MAX is forward when BB = 0
    lft_pulse:
    IF (ServVal_0 = ServVal_0_Old) THEN chkright
    'Only need to send servo data
    ' IF different from last time.
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]136,ServVal_0] 'Set Servo 0 = Left side
    ServVal_0_Old = ServVal_0 'remember value sent
    chkright:
    IF drive.BIT0 = 1 THEN rtfwd 'see comments for left side above
    IF drive.BIT1 = 1 THEN rtbak 'MIN MAX are reversed to reverse
    ' servo direction on other side
    GOTO rt_pulse
    rtbak:
    ServVal_1 = RIGHT_MIN
    GOTO rt_pulse
    rtfwd:
    ServVal_1 = RIGHT_MAX
    rt_pulse:
    IF (ServVal_1 = ServVal_1_Old) THEN DoneServ
    SEROUT To_Co_Proc, BAUD, [noparse][[/noparse]137,ServVal_1] 'Set Servo 1 = Right side
    ServVal_1_Old = ServVal_1 'remember value sent
    DoneServ:
    RETURN
    END
    Post Edited (StampNut2) : 6/10/2006 11:43:37 PM GMT
