datalogging with Palm
I have a datalogging project built with a stamp that records the acceleration and roll of a rocket. The stamp then records the data into an external eprom. Because of the portability needed for the rocket I need a way of downloading the data. I would like to use a Palm m515.
My qustion is can I use a hyperterminal emulator to download the data from the Stamp to the Palm? And if so dose anyone know of an emulator application for the Palm?
Any help would be great.
Tracy Allen
www.emesystems.com
Here is my code for the program. It uses StampDAQ now. But because its in a rocket I need to be able to download the data after each flight at the launch pad. After the data is stored on the Palm I need to be able to download into Excel. Futur versions will use Matlab.
Am I one the right track or is there a better way to acomplish this.
· My SD data logger will be available soon (2 weeks). See www.sddatalogger.com
· I don't know how big your rocket is, but the module is only 1.5" x 2.0".
· It uses very little power, and has 16K of SRAM for storing data fast.
· That data can be written to the SD card (at a much slower rate) by the stamp.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
COMING SOON "SD DATA LOGGER" www.sddatalogger.com
"I reject your reality, and substitute my own." Mythbusters
Post Edited (Bean (Hitt Consulting)) : 6/4/2006 9:14:38 PM GMT
The USB cradle has all the connections necessary for serial connection inside on pads, so it is possible to attach wires to those pads if you are up for a bit of hacking. (I think the M515 uses the 16 pin connector, right?) If you're interested in that, I'll dig up a diagram. The RS232 connection is only three wires, tx, rx and ground. The Palm does not do any handshaking.
Tracy Allen
www.emesystems.com
I opened up the cradle and found the pads
·There are two sides one for USB and one for serial. The pads on the serial side are labled D1 to D6,·P1 to P2, and SH2.
Post Edited (Mike15) : 6/4/2006 10:57:53 PM GMT
Tracy Allen
www.emesystems.com
Im trying to just use my computers hyper terminal to figure the code.(This should work simularly to "Online" right?)
I'm using a seven segment Led to display the digit selected in hyperterminal.
Also the carraige return is not working as I would expect.
Anyone have any suggestions?
You should include an LF after the CR in the SEROUT statements. Hyperterminal by default does not add the line feed. Alternatively, you can go into the terminal properties dialog and check the box to have HTPE add a line feed.
The Stamp Debug window does add the line feed. On Palm, Online will also expect the CRLF sequence to come from the Stamp, although it too has an option to append it locally.
You also asked about using a timeout with SERIN. It depends on the application. If there is something else the program has to do, besides wait for the user to enter a digit, then the timeout can be insurance that the other task will happen.
Tracy Allen
www.emesystems.com
I have doulble checked all the connections and solder joints. Any ideas on what could or could not be happening?
Also for the record, the latest Palms (Tungsten and TX) use the new 18 pin multiconnector, which is different. The serial signals are still there and can be used in Stamp projects, but they are not RS232 levels. They are 3.3 volt True (marking high) levels, and both serial pins are shared as general purpose i/o with the peripheral detection circuitry. That makes it a bit harder to work with.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 6/11/2006 3:58:08 PM GMT
