SX and Darlington transistors
I would like to use the SX28 to drive a Darlington transistor (TIP 120) capable of supplying 2 amps to a stepper motor.· The motor requires 5 volts to operate.· Would it be wise to use a buffer between the SX and the transistor or is it necessary?· If a buffer is necessary could a NAND gate (SN7400N) be used?
Steve
Steve
is doing.· What you do need·however is a current limiting resistor from the I/O to the BASE
of your transistor.
Refer to this link for determining the correct current limiting resistor value.
http://forums.parallax.com/attachment.php?attachmentid=37701
Note:In your case, item #1 would be 2 Amps.··For a Darlington transistor, use 1.2V in the
····· ·formula·for item #4 in place of the .6V
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/8/2006 4:30:24 PM GMT
